What Should I Do??
Old Jan 3, 2005 | 10:07 PM
95LT188ChevyTruck's Avatar
Default What Should I Do??
Well I put a 95 LT1 in my 88 chevy truck... It has little stuff done to it like Street and Performance wiring harness, Chip, Mass Air Flow sensor ported and screens were removed, and cold air intake. I think that is it but I am not sure, that is what I have been told from who I bought it from. What are some pretty in expensive modifications I can do? I am talking about $500 and less for each item Thanks
Old Jan 4, 2005 | 10:16 AM
96SCTA's Avatar
Bigger TB 52-58 mm $300-400
Hand Polish your Intake and heads - New gaskets $100-150
Headers-- Lots of choices
Rocker arms 1.6 to get that extra lift..
But with that all said. You get what you pay for. These mods will only keep you happy for a short time. Then you will hunger more!!
Old Jan 4, 2005 | 10:43 AM
BRENTT94Z's Avatar
IMO Id say headers would be your biggest gain for the buck!
Old Jan 4, 2005 | 04:12 PM
hey what about a cam?? what is like the cam thats gives you the most all around power
Old Jan 5, 2005 | 12:33 AM
anyone wanna help me out??
Old Jan 5, 2005 | 01:13 AM
simple's Avatar
throttle body is not needed and really not a proven mod especially for the money they cost new
its just a big ole airpump, get the air in and get it out as quick and unrestricted as possible
free flowing intake, headers, free flowing catback, then after stuff like that (which are considered basic/standard modifications) open it up and install a new cam, timing set, roller rockers, dyno tune etc. etc.
really depends on what you want out of it....
Old Jan 5, 2005 | 01:16 AM
FIREHAWK #07's Avatar
headers would be 1st on my list....... when i put them on i noticed a big difference......
Old Jan 5, 2005 | 01:39 AM
Vendetta's Avatar
headers, then a cam.
Old Jan 5, 2005 | 02:21 PM
but what kind of cam??
Old Jan 5, 2005 | 02:31 PM
Jordan57's Avatar
I would say a CC305 or similiar. I wouldn't recommend a cc306 or gm847 or a big cam because you need some torque to get all that truck moving. You will also need valve springs too. That with the 1.6rr's would provide a big boost for ya.
Old Jan 5, 2005 | 02:32 PM
Jordan57's Avatar
Oh a stall would go well too....not sure what kind of tranny you have but I'm assuming you have a 4l60e to go with your swap. Throw a 3000+ stall in there. IMO anything under that is kinda useless....cuz you are just going to want to go bigger!!! BTW- LT1's love spray!
Old Jan 5, 2005 | 02:42 PM
you got it... 4L60E with a B&M Shift kit
Old Jan 5, 2005 | 06:36 PM
LoudmouthLT1's Avatar
To beat a modded lightning you are gonna need more then $500 worth of stuff. Your best bet would be nitrous. Just don't tell him you have it
Old Jan 5, 2005 | 07:18 PM
really?? because i have had people say that my truck will run with his lighting and he has a bunch of stuff done to his truck... so maybe my motor has more done to it than i thought?? my cousin lighting has cold air intake, 6 pound pulley, and some other stuff I am not sure
Old Jan 5, 2005 | 07:23 PM
Vendetta's Avatar
4L60E?
Definitely a torque converter.
Old Jan 7, 2005 | 08:58 PM
anything else??
Old Jan 7, 2005 | 10:12 PM
96capricemgr's Avatar
Any other requirments you have of the truck, a little towing or anything or is it just a toy, daily driver? These Camaro guys like BIG cams there are some "milder" cams that will perform quite well and sound wise will pass for stock. The MAF is not helping you and just makes your tuners job harder consider using a stock one. If your usage is as a toy and includes at most light towing then a stall like a 2800or higher Edge, Vig , or Yank would be a great mod. I have a 2800 Edge in My Caprice and tow a little, it is fine even when I had 2.93, even better with the 3.42s, gears should be on your list if they are anything numerically lower than 3.42. Last time I went to the track a friend of a friend had a 2002 Lightening he ran just a tenth or two faster than me the highlights of my mods are a ZZ3 cam(VERY mild compared to what these guys are talking about) the Edge 2800, and 3.42s, the handicaps are stock exhaust manifolds and 87 octane tuning. We were both on street tires, my 60s were better even though I had traction troubles and he did not, was a good bit quicker for the whole 1/8th after that the boost he had made his HP enough to make him faster than my lowend torque made me. My car is probably a little heavier than your truck and will 60ft. better(b-bodies hook pretty well compared to most other vehicles), a set of headers and I would have walked away from him. Another friend with an Impala stock engine, 3K stall Edge, 3.73s, shorties, 93 octane, some lightening for a race weight of probably 4200lbs. and sticky tires was faster than the lightening all day.
Old Jan 8, 2005 | 01:35 AM
well i mean right now its a daily driver... dont tow anything... it was my dads and we put the motor in and rebuilt it as like a project and he gave me it... i want it to just be my toy but it cant happen right now... i want it to sound kinda crazy... not stock but i also want alot of power so what should i go with for a cam??
