fastest times on hotcam
https://ls1tech.com/forums/lt1-lt4-modifications/262757-finally-ran-full-1-4-hotcam-ported-heads.html
https://ls1tech.com/forums/showthread.php?t=262757
Look at his mods though. 11.45:1 compression, trans brake etc. I would just upgrade to something a little bigger.
porting my heads, well I just looked on the internet and saw what others had done and tried to copy, made the port taller and opened it to a felpro 1206 SBC intake gasket port, smoothed the inside wall for better transition, ground on the valve guide bosses and airfoil shaped them, and had a 3 angle race valve job done at houston engine and ballencing where I used to work, pics of the heads are on my cardomain site in signature
and do you get a lot of rubbing with 29.5 tires sorry for all the q's but you are running that same setup just what to hit 11.40's and then the spray that for all your help
and do you get a lot of rubbing with 29.5 tires sorry for all the q's but you are running that same setup just what to hit 11.40's and then the spray thanks for all your help
good luck with runnig 10's any body else running a hot cam
here is one pic, these are the first heads ive ever ported, and most likely the last because its ALOT of work just to get these things to 175 CCs
