Need fuel specs for LT1
key on engine running it should drop around 3psi
engine running vacuum removed from the FPR should go up 3-8psi
key off engine off pressure should hold around 38psi
Wonder what the problem is their. I do know it use to hold pressure before I installed the Aeromotive adj Fuel Regulator. I have 2 of these and one is brand new. They both do it. Any Ideas?
I dont have any visible leaks and the AFPR isnt leaking. Have good fuel pressure. Its possible it could be my Injectors. Im using Accell 30lb injectors I bought new 2 years ago.
but on a more serious note, check the vacuum source for the regulator, does it smell like fuel, or drip fuel? if so, the regulator is shot. i've also heard things about the aeromotive's leaking. not too sure on what causes this. good luck, happy hunting.Nick
Where did you come up with those numbers? Engine idling & vacuum hose off should be 45/47 psi. Pressure drop with the hose on depends on your manifold vacuum.
Take care, Ed
Take care, Ed
Ed
Ed
Good luck, Ed
