what kind of gains could be expected from porting stock LT1 heads?
a friend of mine has a 96 Z28 with longtubes, true duals, throttle body and a cai. a local shop quoted him 500 bucks to port his stock heads and we have heard the guy does badass head work. with a decent cam and his current mods, what kind of gains could be had with ported heads? thanks for any info.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Well, I gained exactly 41 RWhp with a set of GTP Stage 2 heads, I already had a HOT cam installed. BUT, I increased my compression about 1 full point at the same time. The compression increase was probably good for 10-15 HP, so the ported heads were worth 25-30 rwwhp.
Get your heads ported, and the intake ported. Get LE3 heads and a LE2 cam and you'll be at 400 hp no doubt. Also get your intake ported to match the flow and you'll be all set. The heads/cam will work better with:
30 or 36# injectors
3.73 or higher gears
3200+ stall
LT's
no cats
GOOD tuning
30 or 36# injectors
3200+ stall
LT's
no cats
GOOD tuning
What about valve increase? I have a friend at a local performance shop who is a machinist. I can get all the work done for close to nothing so I planned on a port/polish 2.02 int./1.60 exh.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
