fuel system for lt1 with h/c
also, how hard is the 255 pump install?
also one more thing! is it even worth putting an afpr on? i actually ordered one from www.lmperformance.com supposedly it was their slp fpr that converts mine into adjustable, but instead i got this afpr that doesnt appear to fit.. it came in an slp box with slp stickers and stuff but i dont think it fits... anyone know anything about the slp regulators? its got some green on it but other than that its polished with a screw in the top and vac inlet on side.
SVO injectors are cheap and actually flow a little more than 30 at our fuel pressure.
id install this fpr i have but i have no clue how to... tomorrow when i can go get it ill take a picture and see if any of you recognize it because i dont think it is supposed to go on an lt1
now if i go with the 36lb injectors and afpr (assuming i can get mine to fit, otherwise im using stock regulator) i will need to get the car tuned correct? i know i will already have to get it tuned somewhat to accept the new cam and all, but what downsides will i have to using the 36 lb injectors with say 380 hp? id buy them bigger because im probably gonna throw some nitrous at it if i cant get to 4 somethin all motor
You could get one of Lloyd Elliot heads/cam packages, cheaper than AFR's and will get you 400+rwhp with a GOOD CURVE with the supporting mods of course.
www.eportworks.com is his website
See my sig for times with his heads/cam package. Never got a good pass with the 383, it should've gone 11.30's on 16" drag radials no problem though.
