I must have another LT1...
Now, I'm about to be dropped from my under my parent's insurance company (long story) and need another car that doesn't require collision like my WRX does since I'll have my own insurance account. I'm looking at ~90k mileage M6 LT1s for cheap (<$5000) that I can turn into a bolt-on and possibly mildly cammed car to keep me held over until I finish college in two years and am able to get another LT1 project car.
What do you guys think? An early model LT1 won't kill me on insurance, but would definitely be more expensive to insure than a beater. I'm totally split on this issue, but I've been going crazy driving a 4banger grocery getter every day. I don't know if I can wait another two years before I have another LT1
...How many of you guys drive high mileage LT1s? How are they holdin up?
I made the mistake of getting a V6 also as a junior in HS, wasn't til I graduated that I got my Z28.Thanks for the input, I'll keep my eyes open on autotrader.
As far as repairs, the only thing I've had to do to the car in nine years was replace a water pump, two sets of brakes and for some reason mine likes breaking clutch forks, I've had to put 2 in it in the last 3 or 4 years. Slammin' thru the gears all the time probably doesn't help that situation.
As far as the rest of the car, the interior looks brand spankin' new and I havent taken that good a care of it. With a good wax and buff job it would shine like a brand new one, except that one spot with the dent. lol
In my opinion this is the toughest most dependable car I've ever owned, especially under my heavy right foot, I'm rough on vehicles. High mileage................. maybe I got one built during the middle of the week but I personally wouldn't worry too much about the mileage.
. I think i would have had not problems with at least another 30 or 40 thousand in the condition it was in.
I only paid $4,400 for my '95 A4 Z28 w/ 109,000 on the clock last October and while the car was in fairly solid shape on the outside and really nice on the inside, I've already had to replace all four tires, have new brakes/rotors all the way around, add new anti-freeze, fix a transmission leak, fix a vacuum leak that was causing an erratic idle, and now am in the process of having a newly developed oil leak from the front of the motor that needs a bunch of new GM gaskets (water pump), opti & crank cover seals, valve cover, timing cover, oil pan, etc. I've also had the entire fuel and intake systems cleaned as well. Now, nothing major, but still, a lot of things that start to add up over time and that is to be expected with an older car. Period. Luckily (knock on wood!), the car is otherwise healthy and runs great.
But still, it gets expensive and very time consuming if you're busy like me. Anyways, if I had to do it all over again, I would have waited until I could afford a newer ('97ish) LT1 with very low mileage in hopes I wouldn't have to deal with all of this maintenance. I'd personally recommend a nice, fairly low-mileaged '98-'00 LS1 once you could afford it that most likely won't give you the problems an older, higher-mileaged LT1 will. Either way, they're both awesome powerplants that put a huge
on my face everytime I drive them. But for someone like you who doesn't have much money right now, I'd try and find something with as low miles as possible for the reliability factor if you decide you must have another F-body...Just my $.02,
Mike
Like I said, I love my LT1 and will keep it forever, but I wish I would have waited until I could afford a nicer one rather than just buying for the sake of buying since I've always wanted one to go with my LS1. Honestly, it all depends upon your financial situation, time, and tolerance of maintenance accountability in the future...Good luck!
i run this thing hard all the time everyday, at most 8 times a day wot....
as of now, i have a small oil leak (think its the dip stick tube and oil pan gasket cause of cam change)
things i had to replace were the opti spark and replaced it with a dynaspark (no problems yet)
other than that, i love this ******* car, and it sure is a fun vett/ls1 eater =)
Found a 94 Z28, red, with 54k miles on the clock for 6 grand. Great price, I may have to check it out. Only thing is, it's an A4. But it's the best deal I've found so far, so I'm gonna follow up on it and give the dealership a call tomorrow to see what kind of shape it's in.
Pulls very strong, revs fine, no knocks, no ticks, no unknown squeaks. It busts the rear end loose with ease and seems very happy doing it. And the oil pressure is awesome. Original opti-spark and no problems with it.
It pulled a couple cars on my friends brand new rebuilt cammed/exhaust/chip 350 TPI IROC up to 110.
I'm pulling it soon to stick in a 383 LE1 LT1 stoker motor, so I'll post back up with what condition it's in.
Oh, good paint to, except for a slight notch and some spider cracking on the rear bumper. I think someone tapped it.
. If I do pick up another LT1, you'll see me around the baords a lot more than I have been.
