jet hot long tubes
Old Apr 4, 2005 | 04:18 PM
TransAmDave96's Avatar
Default jet hot long tubes
well they finally came in with some nice gaskets might i add they came in peices! will that one primary tube just slide in no problem and have no leaks? and any advice from you guys that have done this would be appreciated.
thanks,
dave
Old Apr 4, 2005 | 09:37 PM
warbird27's Avatar
it slides right in. yes it will leak. try some exhaust sealant on the outside of the slip tube so the sealant goes inside the main header portion.
Old Apr 4, 2005 | 09:38 PM
LoudmouthLT1's Avatar
#1 is a slip tube? If so there should be a clamp with it. I didn't clamp the one on my MAC headers and it's surprisingly not leaking.
Old Apr 4, 2005 | 11:02 PM
screamin94Z's Avatar
a clamp wont work because you cant get enough force on the pipe to seal it. rough it lightly with some sandpaper and put some ultra copper on it. i LOVE my jet hots!
Old Apr 5, 2005 | 09:42 AM
Shawn MacAnanny's Avatar
Mine leaks a tiny bit. It doesnt bother me at all. My intake is MUCH louder than my exhaust leak, hell even my exhaust at idle. It will work just fine. There is NOT supposed to be a clamp there. There would be no where to put the clamp either because the steering linkage is in the way. They are awesome headers though.
Old Apr 6, 2005 | 03:56 AM
12secondDream's Avatar
i can't stand mine after the 20 hour install this past weekend. my car runs like crap!!! most are saying because i have a lot of exhaust leaks and i did a splice job on my o2 sensors cuz i didn't have extensions. i have absolutlely no back pressure and the car has NO power!!! hopefully if i fix the leaks and o2's i willl like it...
Old Apr 6, 2005 | 06:49 AM
Valkyn's Avatar
Mine dont leak from the slip tube, no clamp or selant on it either.
Old Apr 6, 2005 | 06:53 AM
curlyws6's Avatar
I like the build quality of my Jet Hots but don't like that they are so tight against the car (have some banging issues). If I had to do it again, I would go with Pacesetters. PS's allow for a little more clearance space under the car and don't have a slip-tube design.
Old Apr 7, 2005 | 04:33 PM
Alright i finally got my intake back on after fixing the oil leak, and i got the manifold off. now time to put in the jet hots. hopefully they turn out better than 12seconddream or ill prolly torch my car after all this work. anyways, did you guys put them in from the top or the bottom, and which side did you have to jack the motor up for?
thanks
Old Apr 7, 2005 | 04:58 PM
They go on from the bottom. I didnt have to jack up either side of the motor. It all depends on how well your car was assembled. Some have to jack up both sides of the motor and remove the K-member. I just jacked up the car about 22 inches from the K member and both sides slid right in.
Here is a step-by-step install guide of a worst case scenerio.
http://www.theheadfl.com/jethotlt.htm
Old Jul 18, 2006 | 12:46 PM
beast69camaro's Avatar
My #1 primary doesn't leak. I have LOTS of banging under the driver side though: the y pipe hits the floor pan cuz the header exits kind of high. I thought maybe it was manufacturing tolerances so I got my headers swapped out w/ a new set from Jet-Hot and put in brand new polyurethane motor mounts but am having the same problem. This is my second set of headers (I am one of the ones who had to jack up both sides of the motor, so putting in 2 sets wasn't exactly what i'd like to call a good time), and it's frustrating the hell outta me. How many others have this problem?
