LT1 Dyno Archive
Bone stock (MSD wires and NGK TR55 plugs)- 249 rwhp 270 ft/lbs
Ebay knockoff "Kooks" long tubes and ORY (stock catback)- 275 rwhp 301 ft/lbs
Ebay headers and open throttle body (removed stock air intake and elbow)- 288 rwhp 314 ft/lbs
Hurt a piston on the last run above.
It makes 407lbs tq at 3000 rpm.
I will retest on the chassis dyno when it is dropped back in the car.
All Callaway stuff:
383ci, forged crank, pistons, h-beam rods, Oliver 4 bolt splayed mains, CNC LT1 heads with new combustion chamber, zero deck level, Callaway Spec cam, 1.6 RR, 1 3/4 Callaway stainless headers, cat-back
All emissions and noise compliant HP
355 stock bottom end with ARP rod bolts, CC305 Cam, 1.66 pro-magnums, Ported stock heads, 2.00/1.56 Raceflow valves, BBK shortie headers, 52mm throttle body, 4.10 gears and an M6.
290rwhp&330rwtq SAE
Getting Comp Mag 1.6s and Springs and a tune going back shooting for 315rwhp and 340rwtq
1- 388 CI stroker with compression ratio 12:5: ,Eagle rod length 6 inch ,JE pistons flat top ,milling heavy duty oil pump.
2- cam 245"/253" , 612"in/612"ex lsa 107
3-Trick flow 7.10" push rods.
4- M6.
5- 42 LPH fuel injectors.
6- 4.10.
7- LT4 cylinder heads 2.02 intake and 1.60 exhaust with Patriot valve springs.
8- porting the intake to 58mm with throttle body.
9- headers 1 3/4 with cat back borla.
10- ram air.
11- EGR,AC,Air deleted.
12- Cloyes double chain roller.
13- Walbro 255LPH.
14- LT4 knock module.
15- electric water pump.
16- under drive pulley.
17- AC deleted kit.
18- LTCC coil conversion to 8 coils.
19- Stage 3 clutch.
Rebuilt bottom end, stock pistons,rods,crank.
advanced induction cam, bolt-ons, stock heads, stock gears
354rwhp, 366rwtq
Mine crossed at 4,200? what does that mean..??? Would I make more or LEss if it crossed at 5250?
