passing emissions test with LTs
Well im getting a catless y-pipe and I was figuring when I went to get my emissions test Ill just wield a cat on real quick for the visual test. Since when they test they just plug into your OBD-2 computer and scan it, can I just have my 2 rear 02 sensors removed via a tune and still pass the emissions test?
-J
I got my EGR and A.I.R pump deleted from my car, and i still passed, and I also have a catless Y pipe, but i have o2 sims....
i can see how the code delete would make the SES light off, but i think the not ready condition would show up for the emissions test
unless someone can give me a diffinative answer, im going to try this: ORY and no slims with code delete, try the emissions, if i fail im going to buy the sims and retest, if i fail again, you will see a new thread on LS1tech
-J
Here's the deal (or what I've discovered so far).
I have long tubes w/o egr, air, etc, and I had O2 sims in place of rear O2s. When i went to pass inspection I came up with (i believe) 4 not readies. One for EGR, one for AIR, and 2 for each rear O2. I had EGR and AIR programmed out, and my O2s had the sims plugged in. I was throwin no SES lights, but still failed...twice. From what I understand, 98 and older vehicles are allowed to have 2 not readies. Being that you have EGR and AIR, and just have your rear O2's programmed out, I think you will be fine. 98 and up are allowed only one not ready. If you do throw a cat in, remember you MUST go through a GM OBD2 drive cycle, other wise your O@s will still come up as not ready.
Best of luck, I hope your results are better than mine.
PS- sims or having the rear O2's programmed out does not matter, they both end in the same result...a not ready. All a sim does is trick the computer, all a program does is force the comp to ignore it.
that's very interesting...maybe i'll run mine through the drive cycle and give it another shot. Thanks for the input.
I also have N/A next to EVAP, why doesnt that one register as not ready or incomplete? From what I know, my evap system has no problems but reads N/A?????
I wish someone could find the magic answer with EDIT!
