lt4 help please.
Old Jun 10, 2005 | 08:05 PM
1970judge's Avatar
Default lt4 help please.
well i decided not to use that 383 i have for now...im just going to buy that lt4 conversion kit..i need to know all the parts i will need extra from someone who has already done this swap...i heard the hotcom doesnt give that badass idle sound so what alternative cam can i use?..help appreciated thanks guys.
Old Jun 10, 2005 | 09:14 PM
slowmofo's Avatar
gm 847
Old Jun 10, 2005 | 11:22 PM
1970judge's Avatar
thats good for a cam but what other parts will i need to go with the lt4 conversion kit
Old Jun 11, 2005 | 12:01 AM
Beast96Z's Avatar
The conversion comes with all the gaskets and things for the upgrade. It also comes with the 1.6 rockers. The only thing I can tell you is that this kit does not favor well with automatic cars. It seems to do ok in 6-speeds. The only option I would do is order the CNC ported LT-4 kit from Scoggs and dickey and use the 847 cam. You would have to get the right springs for the cam, but if you go through Kris at SDPC, he can take care of any and everything you want/need.
Old Jun 11, 2005 | 12:08 AM
1970judge's Avatar
why doesnt it work well with automatic cars? cuz my car is an automatic
so far this is what it looks likeill be getting.
AFR lt4 heads
lt4 intake
lt4 extreme duty timing kit
the gasket set
847 cam
crane roller rockers 1.6
comp chromoly pushrods
havent found a set of springs yet
so will that setup work?..any suggestions?...
Old Jun 11, 2005 | 08:14 AM
Jordan57's Avatar
skip the extreme duty timing set. its a waste of money. Go cloyes double roller if you want a step up from stock. The setup will work with autos, just needs a good tune and a decent sized stall. 3200ish and get your tune from ed wright, pcmforless, ion...or similiar. Spring-wise...just get them from comp or SPDC when you call them. Good luck.
Old Jun 11, 2005 | 04:54 PM
Saad06's Avatar
why the LT4 conversion?.. with the money spent on that, you could build a stock LT1 to be MUCH better. right?
Old Jun 11, 2005 | 05:02 PM
1970judge's Avatar
no because i already have a 383 ready to go in this car..but i dont get the engine til i move back home next summer..so until then im going to put a few things on it..
Old Jun 11, 2005 | 10:15 PM
Jordan57's Avatar
Another option is the famed Lloyd Elliot Package. If you got the LE2/3 setup, plus a decent valvetrain you would spend approximately the same money, make more hp, and have a setup made especially for you. If I was going to spend close to 3K on my car (which I am) I would go that route.
Old Jun 11, 2005 | 10:27 PM
METALBEAST's Avatar
I would talk to Lloyd Elliot. Biggest mistake in doing something like this is just throwing parts that you have "heard" makes great power. Lloyd can set you up with a specific combo to suit your needs.
Old Jun 12, 2005 | 07:36 AM
Smokinlt1's Avatar
Gotta go with Lloyd, you can't beat his prices.
Old Jun 12, 2005 | 08:30 AM
shipwreck's Avatar
i just added a post talking about lt4 conversion and summit has the top end part, heres the part number and info, go to summitracing.com if its worth a crap i dont know. thats what my post is actually asking. maybe i should ask lloyd about it, i heard he's like yoda of lt1 engines. "may the horsepower be with you"
NAL-GMP3287-1
Turn your LT1 into the engine it wants to be.
Have an LT1, but want an LT4? GM Performance Parts has what you need. These LT1-to-LT4 conversion kits bring the most out of your factory LT1 engine. The kits include LT4 cylinder heads with valves and springs, a red aluminum LT4 intake manifold, GM Performance Parts' hot cam with 1.6:1 ratio Bow Tie roller rockers, and all necessary gaskets. The result of all of these mods is 425+ proven horsepower!
