What Do I need to break 11's?!
18k miles on 383 ci motor, Forged crank, and rods, kb 10.5:1's. 4l60e built by B&C transmissions, 3500 stall by Midwest convertors. Auburn center section, 3:73's. Comp cams 304 cam, and cc springs. Mac shorties and flowmaster muffler. Custom intake, 1le intake elbow, one off throttle body-dual 55mm,
ed wright ecu.
also, the car went 13.0 at 108 through the factory catback, stock intake and stock tires...It now has different exhaust and an intake, and has been tuned up. As of now I'm almost sure this is a mid 12-second car.
Car has COMPLETELY stock suspension. I figured SFC's and LCA's and a set of DR's and I should be extremely low 12's/high 11's. Car will be put on spray next year, and I hope for LOW 11's.
heres all you need to do to that setup. yank the tiny *** cam out, put in something bigger. put some longtube headers, and dump the flowmasters for something better. like a borla, or a GMMG. and if for some odd reason that doesnt get you there. drop a nice 150 shot of giggle gas on it. and put it on some DR's
ok i havent had any sleep and got carried away. dont do any of the above mention things, but if you do, please take pics and remember to share.
The car needs to be considered a "street car." I need to keep @ least the passenger seat and radio and the I CANNOT cage the car in any way (scares people away, obviously).
BrettZ, you hit the nail on the head. I want a quick car that leaves HARD on the street.
My main concern right now with the car is a proper heads/cam/intake setup. Anyone voting? I need some opinions.
Nuff said!
The current heads and cam are killing that setup. LE2+ported LT1 intake would be the cheapest and best performing way to go IMO. If you've got the cash to do it, ported AFR LT4 castings and a ported LT4 intake may get more out of the setup for you.
Yeah I didn't see the stock heads in your sig. They are choking major HP. Wow...def need LE3. Should be a good swap unless you want something more serious...in which case ask me because I am pure race only :wink:
I would rather go with the LE3 ($1,850) to get the gm847-or-so sized cam (plus I have the 3500stall tq and 373s)...could I also use a ported LT4 intake on that setup?
