I need help with my ratio! please!
could someone please guide me here, I need to get it changed asap...this current ratio is killing me.
I personally went cheap. Found a used 10 bolt from an M6 car, to my advantage they had already welded spohn LCA relocation brackets to it. So I was good to go for $40.
z28boy is right your rea should be a 2 series carrier, u have to find a set of 3.42 2 series, or just go get a 3.23 or higher rear. I got a 3.23 rear with T/C for about 150 bucks, at a local junk yard, then put my new gears in.
but as some of you said a 3.73 would do better job....but what abot the top speed? I mean the higher I go the less I'm gonna get on my top speed right?
