Eldelbrock...AFR...or LT-4?
i like the eldelbrocks because they make a decent amount of power for the money plus my intake is ported(even more power).
as always thanx for your knowledge!!!
SWING EM'!!!
no i dont just read ad's i like the real info.
thanx for the info
thanx for the info
Oh its great..!! I have just get my 210cc competiton heads from AFR (after 14 weeks backorder) and I see these posts.. On their website these heads flow 288cfm @ .600 ,but I don't know how much of this flow number will change after LT4 intake..
Lift Int Exh
.100 75.6 67.3
.200 155 118
.300 210 156
.400 255 182
.500 285 191
.550 293 196
.600 296 200
.650 296 204
.700 298 208
Here is an example of AFR 210's that were purchased bare and then ported by Lloyd Elliot:
Lloyd Elliot AFR LT4 210CC flow numbers on a 4.030 bore.
.........Intake.......Exhaust (no pipe)
.200...143............103
.300...204............141
.400...247............173
.500...281............198
.600...308............219
.700...311............227
I know that flow numbers aren't everything, and AI will tell you that when you talk to them, but Lloyd Elliot's work speaks for itself with the HP that he makes. I don't have any doubt that AFR does a decent job on their porting, I just don't think that they would spend the time, effort and detail that a reputable porting company would. Trick flows can be purchased through Summit Racing bare!
Thanks for detailed explanation.. I see there is a big difference between lloyd and AI job.. 296cfm @.600 (AI) and 308cfm @.600 (Lloyd) .. So is this healty (safe)? I mean AFR porting is 288cfm @.600 and a huge difference here..! I have no doubt that AI and Lloyd are the BEST porting companies ,but I think this is "pushing the limits".. If you want 300+cfm go with bigger heads 220,227 or 215rr ..
Those LE AFR 210 are not anything special. The CNC program that AFR uses actually has better exhaust flow. The difference in the intake flow #s are not enough to benefit especially if its a power adder car. Also flow numbers dont mean everything. Port velocity and low lift #s should be looked at to just as close. My LT-4 heads ported by GTP flow 290 on the intake and 234 on the exhaust and that is at .600 lift. If you want the strongest head that offers the thickest deck go with the AFRs. Also they will make the most power 9 times out of 10 if they are ported correctly. LT-4s would be your second choice.
Yep, you are right, LE is not "Special", but he defintely knows what he is doing, you can tell by the HP his head and cam packages make. And, yes, if you read my previous post, you will see that I posted that "flow numbers aren't everything." But, I can tell you that if I got a set of AFR 210's back that I paid $2,000.00 to have ported and the porter claims that they flow 260cfm@.600 lift, you can guarantee that I am going to be suspicous. I have pretty much chosen to go with AI to do my heads and I can guarntee that they don't go strickly by flow numbers, do a search on www.camaroz28.com and you will see that for yourself. But, GTP's are the ones that I would be suspicous of, their heads have been know to flow WAY different than what they claim, not to mention that their customer service is HORRIBLE!
I have seen the work from both LE and AI and its very nice. Im not saying who is better or worse. Maybe you misunderstood. I know what most LT-1 or 4 heads are capable. It just seemed everyone was reverting back to flow #s. On the other hand my GTP heads flowed exactly what they said when we checked them. Customer service has been great for me and with the fact that 2 of the fastest LT-1s right now run his stuff speaks pretty strong. My new 215 RR that he did are wicked. Good luck with your build.
She Likes When I'm Gentle, But Loves When I'm Rough!
Flow# LE AFR 210 bare heads "no porting"!!
.2 136/99
.3 197/135
.4 239/167
.5 276/188
.6 296/205
.7 301/219
