speed governed at 105?
Old 08-16-2005 | 01:13 AM
private area's Avatar
Default speed governed at 105?
OK, i have a 94 trans am non-gt it has the low wing (v-6) and my speedo goes to 110. plus it's governed al 105!!!! (kinda pissed) o'well? is this all normal? i bought it because it has 105K and runs very strong. Plus i got one hell of a price for it. anyways, is the whole speedo goes to 110 normal and how about the 105 govern?
Old 08-16-2005 | 02:02 AM
97MysticZ's Avatar
What's a Sticky?
I am not a T/A expert or anything but are you sure its a T/A and not just a Firebird? Cause that sounds like you got a v6 on your hands. But thats just what it sounds like- like i said, im not a T/A expert.
Old 08-16-2005 | 02:04 AM
Vendetta's Avatar
It's normal, that's a kind of stripper option. The car came like that brand new from the factory with some **** tires too. I don't know the details though, we'll let one of the gurus come in and handle that part. You can get the governer removed with a programming.
Old 08-16-2005 | 02:20 AM
yeah, i had bought the car, got there and was like what the heck. But when I opened the hood I was happy. any way to swith to 150mph guages?
Old 08-16-2005 | 02:26 AM
infinitebird's Avatar
It's normal. I have the exact same thing. (94 TA with low spoiler, 105 governer and 110 speedo). Now I've got to get rid of that ****.
Old 08-16-2005 | 02:27 AM
Yes, you can swap in a 150mph gauge fairly easily. It's a direct swap, no rewiring or reprogramming required.
Old 08-16-2005 | 02:35 AM
by plug and play you mean i dont even have to do a "program tune" to compensate for the 110-150 mph swap? plus what if i want to go to the digital odom.?
Old 08-16-2005 | 02:39 AM
That's right. All you have to do is change the cluster. Any 94-96 cluster should work fine.
You would need some reprogramming/rewiring to do that since that would be reading the mileage from the pcm.
Old 08-16-2005 | 02:46 AM
Vendetta's Avatar
I actually like the lower spoiler, I think it makes the rear of the car look beefier.
Old 08-16-2005 | 02:49 AM
Yeah I don't mind the spoiler. I really don't care either way.
105 governor sucks *** though.
I ran a C5 the other day, and I kept up with him pretty good until that.
Old 08-16-2005 | 04:25 PM
ExtinctBird's Avatar
My understanding is that LT1 cars that came without Z rated tires got the lower speedometer and governor. You will need to have the governor programmed out, whether you change out the speedo or not. If your car is a TA, then it has a V8 LT1. The low rise spoiler is the normal rear on most Formulas as well, so consider yourself lucky on that point. (Mine is a 95 Formula.)
Old 08-16-2005 | 04:36 PM
RoAdRaGe912's Avatar
bingo, you should also have 2.73 rear gears. but the car definitey came from the factory with non Z rated 235 wide crap tires.
edit- i have a 150 mph cluster out of a 94 Z28 if anyone is interested. pm for details.
Quick Reply: speed governed at 105?
