anybody running msd digital 6 plus ignition?
Old 10-04-2005 | 10:15 PM
00Z-28-LT1's Avatar
Default anybody running msd digital 6 plus ignition?
if so how hard was it to wire and would you recomend it over the 6-AL. im looking at it or the nitrous retard option and increased spark, plus all the other great features.
Old 10-05-2005 | 10:47 PM
00Z-28-LT1's Avatar
ok, so i guess ill be the first one to try it as soon as i can save up the cash to buy it...
Old 10-06-2005 | 12:14 AM
pigpen's Avatar
I've bought one, but havent installed it yet.
From what I've seen, you can use the same harness that the 6A and 6AL box uses. So it should not be any harder to wire up, than those 2 boxes, with the exception of wiring up the additional functions that the digit 6 box has.
You can always go over to the MSD Ignition websight. They have the wiring diagrams and instructions for all their products online.
Old 10-06-2005 | 01:05 AM
buffman's Avatar
I know a few people who have them installed on their LT1 cars. It's not too difficult.
Matt
Old 10-06-2005 | 02:59 AM
SmokedOutZ28's Avatar
very straight forward to install if you have the harness adapter, and the other functions will come with instructions on how to activate and use them as well.
Old 10-06-2005 | 11:53 AM
Chris 96 WS6's Avatar
I'm not a fan of aftermarket boxes on top of the optispark. I've seen and heard of way too many opti's dying from the added juice and/or multiple spark.
Old 10-07-2005 | 01:57 PM
pigpen's Avatar
What are the definitive signs that the aftermarket boxes cause problems with the optis?
I've ran an MSD box on my 93 since 96 and have only had to replace 1 opti (non-vented), back in 98 - I pulled it off in 03 and it looked great.
My buds LT1 has had a 6A box since 98 with the same opti - looked at it last month while trouble shooting another problem - and it looked great as well.
Only thing that I saw on these optis was a little wear on the cap, at the inside of the post. Nothing very bad - might consider replacing the cap and rotor every 50k or so while running a high fire box, but I don't feel that's too much to ask.
Old 10-07-2005 | 06:43 PM
97LT1's Avatar
I didnt see any real gain from the Dig6 on my car. I think the stock ignition does a good job for spark strength. like said above less problems. They will burn your coils up quick.
Old 10-07-2005 | 07:56 PM
Speed Density's Avatar
hashtagBMW
Isnt it only really nescacary to get aftermarket ingition for FI and NOS? I mean Ricers do it cuz its a nice lil box for there engine bay, it really makes those 4cyls shine.
Old 10-07-2005 | 08:30 PM
Turbo_6's Avatar
Even with a '96 or newer ignition system on the LT1's that was improved over the '95 and earlier models, the stock ignition does have trouble over 6,000rpm. If you are making a decent amount of power over stock and spinning the motor then it is well worth the money. As stated above, for forced induction/N20 it is pretty beneficial.
Old 10-07-2005 | 08:31 PM
buffman's Avatar
Not necessarily. my friend has had the same 6AL box (now has a digital 6 on his current car) that he's put on every single car he's owned in the past, well the ones that were more performance oriented, and he documented that he always got better gas mileage with the box installed.
Quick Reply: anybody running msd digital 6 plus ignition?
