How Much Can they flow?
Old Oct 18, 2005 | 04:17 PM
SmokedOutZ28's Avatar
Default How Much Can they flow?
What is the highest flow numbers out there for Stock ported heads & who does the porting? Is it possible to get Stock castings Aluminum LT1 heads into the 300cfm on the intake and 200cfm on the exhaust??
Old Oct 18, 2005 | 04:27 PM
roughneck427's Avatar
check this out alot of flow comparisons to different head porters and LT1 LT4 heads http://www.malcams.com/legacy/misc/headflow.htm
Old Oct 18, 2005 | 04:53 PM
good site, anyone got some real world numbers of ported LT4 heads?
Old Oct 18, 2005 | 05:16 PM
SStrokerAce's Avatar
Ai claims that they can.... I would like to see it on a bench myself.
Some of the really expensive race LT1 motors with stock castings can move 300cfm, they aren't going to work on a street car and you would spend half as much on some well prepped AFR's or TFS heads.
To quote Dennis@Airflowresearch on the topic...
"And YES to answer the ellusive questions everybody asks...there ARE ltx heads that go over 300cfm... We have had a program for this since 98...how well do they work on a street car?...not very....
Welding (on race LT1 castings) would be an understatement...
If I get a chance, I have a set in development right now. I will snap some pics for you guys.
.....These heads go on cars that leave vertical, turn 9200+ revs and consume 3/4 of a gallon in 1320 feet....If you must have a set, their are no returns and the cost is north of $7k.
....Our current "C" heads require about 210 hours of prep work. At that amount of time $7400.00 is a bargain. These heads propel 3410lbs to 8.96 seconds in 1320 feet.
Like I said, these are not for the street. Much easier ways to go faster for less. The point of this thread was to provide some simple concepts to make the ltx heads work for the DIY guy."
Bret
Old Oct 18, 2005 | 05:30 PM
Bret
thank you for that post.. i have no plans on going to 300 cfm for that price but i see it's possible. Im on the market for some new heads for this winter and i want some good flow numbers all across the board just not at high lift #'s so i debating if i should pay to get the stock ported or just by some LT4 heads and get those ported for even better results. All i really want is low 11sec traps with the stock bottom end, i rarely go to the track and i don't want to use spray so i know with the right heads and cam i can achieve that goal with no problems.
Old Oct 19, 2005 | 04:35 AM
sssalah's Avatar
My LT4 heads were ported by Lloyd Elliot and they flowed 305cfm and 200cfm. The flow sheet's at home but I remember the low lift numbers were also good.
Old Oct 19, 2005 | 07:35 AM
automotivebreath's Avatar
For LT1 head porting, Lloyd Elliott has lots of experience.
he's at www.eportworks.com
Here are links to his 3 basic levels of LT1 porting:
LE1 http://eportworks.com/LT1LE1.htm
LE2 http://eportworks.com/LT1LE2.htm
LE3 http://eportworks.com/LT1LE3.htm
Lloyd is very customer friendly and available to talk.
Old Oct 19, 2005 | 07:53 AM
Thats good to hear, if you don't mind me asking what was the charge to port those heads? I can't make up my mind if i want to spend the money to port the stock castings or get new heads.
Old Oct 19, 2005 | 07:59 AM
Thanks for the info, but i know lloyd i have talked to him several times in the past about his LE3 package. But i found a local guy that says he can achieve the same flow numbers that lloyd achieve's in his LE3 package for a little cheaper in price.
do you know if lloyd changes valve guides?
Old Oct 19, 2005 | 08:56 AM
sssalah's Avatar
If I remeber correctly it was $1675 for the complete job which included porting, new valve seats, new valves, springs, assembly and a custom cam.
Old Oct 19, 2005 | 01:06 PM
GreenbeanZ28's Avatar
I've seen them on the bench myself
AI's CNC stuff is around 285 intake/200 exhaust. You want more than that, AI can get more. But flow numbers are like dyno sheets...they dont mean a damn thing.
Good thing AI's stuff actually runs well at the track.
Old Oct 19, 2005 | 07:21 PM
Quickshotkimber's Avatar
I heard Phil just did that to see if it could be done without welding anything. Pretty impressive. I'm very interested in a set of thier CNC LT1 heads. I'm all about real world performance, not internet bandwagons with NO NUMBERS TO BACK THEM UP!
Old Oct 19, 2005 | 09:51 PM
do they customize cams to there heads? also whats some "real world" track #'s for there heads? also how expensive are they.
Old Oct 19, 2005 | 10:12 PM
I've seen their stuff on my bench and it does close enough to what they say that I agree with it.... but still haven't seen the 300cfm LT1 heads.
Bret
Old Oct 20, 2005 | 08:41 PM
Joe Overton's Avatar
James funny you mention that..I havnt seen any good numbers in quite some time.. seen alot of foreplay, but no real action... I have a funny feeling though things are about to change...
