Elliot's flow results
Old Nov 18, 2005 | 12:34 PM
Juicedz's Avatar
Default Elliot's flow results
The heads are AFR 190, w/ 2.055 intake valve and comp beehive springs here are the numbers..........
Lift Intake Exhaust
.2000 136.6 109.4
.2500 164.4 128.0
.3000 197.8 144.5
.3500 221.4 161.0
.4000 239.1 179.7
.4500 259.7 192.0
.5000 276.1 202.4
.5500 282.6 208.6
.6000 286.6 212.7
.6500 288.2 216.8
.7000 286.2 220.9
Lloyd did an excellent job!!! Turn around time was great, customer servive was the best I've ever had, and his prices were very nice.
BTW These are heads are going on 358 w/ LT4 intake, holley 58mm t.b, 38lb injectors, turbo 400 with brake and 4000 stall. I will be running one of Bret Bauer's nasty cams( 24X, 24X) 10X LSA and lift needs to stay pretty confidential. I have a NX direct kit, spraying 200-250 shot. Hal's QA1 "R" serires, hoosier 28x10 and skinnies up front. Now for my goal, one of very few non-stroked, hydraulic roller cam, and single power adder to be in the nines. I'll be going to the dyno next week to get and tuned and dynoed, stay tuned for the results..........
Old Nov 18, 2005 | 12:48 PM
Quick96ss's Avatar
That is awesome hope you hit your goal.
blkchevyz's Avatar
sounds like a hell of a motor.
what compression you going with?
Old Nov 18, 2005 | 12:49 PM
Juicedz's Avatar
thanks alot, it is around 11:1
Old Nov 18, 2005 | 04:20 PM
Tireburnin's Avatar
Where are you located at? You have nearly the same setup as me.
It'll be interesting to see what you run.
Old Nov 19, 2005 | 11:58 AM
Juicedz's Avatar
I live in Omaha, Nebraska, have you had yours at the track or dyno tireburnin?
Old Nov 19, 2005 | 02:56 PM
zigroid's Avatar
they flow pretty well. about even with mine (who are also from lloyd) but yours start to pull ahead over .550" and peak a good 15 cfm higher. thats a massive intake valve too! did you have him port your LT4 intake? he did a great job on my LT1 intake.
your setup isnt too far off from mine, obviously a bit more race oriented.
Old Nov 19, 2005 | 05:30 PM
T/ALT1's Avatar
Nice numbers they look very similar to my Trickflows that Lloyd did for me. You should run 9's pretty easy with that setup. My car ran 10.17@134mph on n2o with the LT1 castings on drag radials. With the new heads and LT4 intake my car should run 9's pretty soon with an old hydraulic CC306, 355"LT1 and drag radials. Tehn I plan on stepping up the camshaft to see what it will do. Later Clint
Old Nov 19, 2005 | 05:37 PM
transamtom's Avatar
Nice #'s good luck with the new pkg and post some times when you get them
Old Nov 20, 2005 | 01:10 AM
Juicedz's Avatar
I bought a lt4 intake and he ported that
Old Nov 20, 2005 | 01:11 AM
Juicedz's Avatar
Clint, what was intake/exhaust at .600 and .650?
Old Nov 20, 2005 | 03:36 PM
TwoFast4Lv's Avatar
Nice numbers! We just got 448RWHP out of a set of AFR 210's Lloyd did through and A4 and a 12 bolt
I think you will be happy
Old Nov 20, 2005 | 10:58 PM
Juicedz's Avatar
twofast4lv, any info on head flow numbers and cam specs?
Old Nov 21, 2005 | 03:03 PM
T/ALT1's Avatar
These are the numbers I got from Lloyd. later Clint
.2 137/107
.3 197/141
.4 250/175
.5 281/204
.6 290/219
Old Nov 21, 2005 | 03:22 PM
Tireburnin's Avatar
I don't have any real numbers from the car yet.
Everytime I hit the track, I break something. Haven't gotten a clean motor pass let alone tried the spray yet. From broken rear ends to transmission slip...I keep finding my weak links.
I have dyno numbers, but I also have a big stall th400...so they don't mean anything.
If you were closer, it would be fun/interesting to run them.
What gears are you planning on running? What RPM are you shifting at?
Old Nov 21, 2005 | 03:32 PM
Juicedz's Avatar
tireburnin, I am running 4:10 and I have no idea where I will shift at probably around 6700, I go to the dyno on Wed. Also, I feel your pain man I have a th400 and a 3800 stall.Besides are we dyno racing, I've learned to use the dyno as a tuning tool and a before and after comparison.
Old Nov 21, 2005 | 03:36 PM
Juicedz's Avatar
Does anyone know what kind of gains I could see. Last time I dynoed I had untouched afr 190's with 2.02/1.60 valves, zz-409 cam(226/226, .554/.554) 52mm t.b. , stock 24lb injectors and a untouched Lt1 intake. Now I have my worked afr's by Lloyd with 2.055 valves, cam by bret(specs above) 58mm t.b, 37lb injectors, and a ported Lt4 intake. Also will I see a decent gain with the nitrous since I am running a sl=plit duration cam compared to my single pattern? (200 shot)? thanks guys
Old Nov 21, 2005 | 06:04 PM
Hybrid86Z's Avatar
nice setup. here's my specs on the AFR 190cc's after LE put the grinder to work. I can't wait to get 'em on the car w/ the new Bauer camshaft I got
Flow numbers:
Lift In. Ex.
.200 140 90
.300 204 128
.400 248 155
.500 278 182
.550 280 195
.600 301 210
.650 304 212
Old Nov 21, 2005 | 08:14 PM
METALBEAST's Avatar
Was that on a stroker motor Ellis? Nice numbers!
Old Dec 25, 2005 | 01:39 PM
Evaporate's Avatar
I know this is an old thread but I was wondering how much difference fully ported LE stockers compared to fully ported 190 AFR LE's make. Do you guys find it to be worth the difference? Any track or dyno results for comparison? I'm concerned primarily with mid-size cams in the 226/234 range.
Flow numbers:
Lift In. Ex.
.200 140 90
.300 204 128
.400 248 155
.500 278 182
.550 280 195
.600 301 210
.650 304 212
