optispark
Old Nov 21, 2005 | 04:39 PM
blindman23's Avatar
Default optispark
ok im a newbie and have seen people have alot of probs. with the optispark, so my question is what the freak is a optispark, i just got a 95 ta, and it misses pretty bad so we changed plugs and wires and still no fix, is this the optispark and what the heck is a optispark so i can finally know.
Old Nov 21, 2005 | 04:43 PM
infinitebird's Avatar
Optispark is the distributor, sends spark to the cylinders.
Old Nov 21, 2005 | 04:58 PM
Jordan57's Avatar
if it's cutting out, sputtering, dying, etc it is probably the optispark. It is located underneath and behind (sort of tucked actually) the waterpump. To replace, the radiator, air intake system, and waterpump come off and there she blows. For the cheapest route, you can get a new OEM piece from samtaylor.com for something like 239 shipped.
Old Nov 21, 2005 | 06:30 PM
96capricemgr's Avatar
The biggest problem with the opti is NOT the opti but rather the cap and rotor cost more than other distributors and are harder to change so people neglect them and they cry when they eventually act up but ANY distributor will act up eventually if the cap and rotor are left on as long as many are on the opti. Is it perfect no but it's reputation is FAR worse than deserved mostly because people lack anything resembling reasoning skills these days. Other distributor caps and rotors are frequently changed with the plugs and wires because they are a wear item due to the spark having to jump the gap from the rotor to cap.
Old Nov 23, 2005 | 08:30 PM
Cheater's Avatar
you wiil deff find out what it is before long!!
Old Nov 23, 2005 | 09:40 PM
State69champ's Avatar
I didnt have to take out the radiator, just the fans for the crank shaft pully puller. Im putting everyting back togather basicly all i have left is the water pump and fill the radiator... i have only worked on it for an hour. (thats to put everything togather)
Old Nov 24, 2005 | 07:24 PM
RAREBREED95's Avatar
Default Opti Spark
I Have Just Changed Mine , 95 T/a 6 Speed Car Was Starting Intermittent . Changed Now Car Ran 10 Miles Died Will Only Crank No Fire . Did The Change Help You And Where Didi You Buy Yours. Orielys ,mine
Old Nov 26, 2005 | 09:00 PM
taner's Avatar
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
if anyone is interested i will be selling my Dynatech Dynaspark distributor very soon! paid 613 to my door 500 to your, has 12 passes on it.
i have to disagree, my stock optis never lasted! at least the dynatech has held up just fine!
Old Nov 26, 2005 | 09:29 PM
SS MPSTR's Avatar
I run it too and love it. $500 is a great deal.
Old Nov 27, 2005 | 09:42 AM
Ed Wright's Avatar
9-Second Club
Whatcha going to use now?
