car stumbling bad
Old Nov 21, 2005 | 11:15 PM
xtinctbird's Avatar
Default car stumbling bad
my 95 z has developed a nasty habit whenever you come to a stop it surges and stumbles real bad unless you put it in neutral then it only does it a little. when driving there's a little surge but it only gets real bad when you come to a stop and idle, any ideas?
Old Nov 22, 2005 | 11:09 PM
xtinctbird's Avatar
anybody got any ideas?
Old Nov 22, 2005 | 11:37 PM
projectcam's Avatar
Unplug your MAF sensor and check if it gets better. My car did the same thing and wasnt throwing a code but when I unpluged it, the stumbling went away. Did you port your Maf sensor?
Old Nov 23, 2005 | 06:08 AM
xtinctbird's Avatar
maf was ported when I got it I'll unplug it this morning
Old Nov 23, 2005 | 05:56 PM
SCMedic's Avatar
I'm having the same problem....my MAF is stock...Unplugging didn't work..
Old Nov 23, 2005 | 08:49 PM
projectcam's Avatar
Check your vacum lines, do your brakes feel any different?
Old Nov 25, 2005 | 05:00 PM
SCMedic's Avatar
Brakes feel fine in mine...No check engine light, nothing. Just idles rough, and stumbles at low RPM..Above 2500 or so feels smooth except at tip in when you first roll on the throttle..It stumbles, and then goes..
Old Nov 27, 2005 | 01:41 AM
VanbibberLt1's Avatar
i know everyone hates when its said BUT: Optispark.
mine did the EXACT same thing, no SES lights. every time i had to stop at a light i thought the car was going to blow up from the way it was acting. if i put it in neutral it wouldnt be as bad but it was still there.
at first i thought it was maybe a bad o2 or the fuel filter, i changed those out and it still ran like ****. i went through the car and couldnt find anything wrong. my last ditch effort was the opti. sure enough it was, i replaced it and it runs perfect again.
Old Nov 27, 2005 | 08:44 AM
SCMedic's Avatar
I just replaced the opti and the water pump....
Old Nov 27, 2005 | 08:49 AM
xtinctbird's Avatar
I'll be ordering an opti this week, any ideas of a cheap place to order one?
Old Nov 29, 2005 | 01:50 AM
there really isnt a cheap opti. mine cost around 400 when i replaced it. check your water pump also. mine went bad and caused the opti to take a crap.
if your going to do it yourself make sure you have plenty of time to do it. its a pretty long drawn out process to do it.
check here for a few good writeups for how to install it yourself http://www.bfranker.badz28.com/fbody/Guides.htm
Old Nov 29, 2005 | 07:53 AM
dhdenney's Avatar
I got a decent deal on mine through Ebay. I believe the dealer was Jennings Chevrolet.
Old Nov 29, 2005 | 01:49 PM
tekprodave's Avatar
$400 for an opti? Yikes!! If you are going to pay that much then get the MSD version for $500. Or do like I did and call up Jason Cromer at Sam Taylor Buick and get a vented one for $195. And I found out that wasn't even the problem.
This can be caused by several things. In my case the ground had come loose on my ignition box. It could also be plug wires, or other related things. If it happens while driving it could be the EGR valve. Try to eliminate the easier and cheaper items first. I would start with the plug wires.
Old Dec 1, 2005 | 02:31 AM
1bottled93toenvy's Avatar
i got just the cap and rotor kit from MSD for 150 and i am doing it tomorrow....well see if only changing the cap and rotor will fix my problem..but i got mine from summit...
Old Dec 1, 2005 | 10:43 AM
SixReasons's Avatar
my car is kinda having that same problem click here
https://ls1tech.com/forums/showthrea...17#post3871717
