Stock Rods.. How strong?
Anyways, through me some tips and ideas... I am going to have everything balanced, how many RPM's will the rods hold with these heavy pistons...?
DOES ANYONE NEED RINGS? I HAVE A SET OF MOLY RINGS I CAN"T USE! YOU NEED"EM AND I DON"T >> SELL"EM TO YA CHEAP! My lose your gain.
most fbodys got the 2 bolt, vettes got the 4 bolt.
The weight is a bit heavy, but if you go with a lighter piston you'll pay more for them. As far as the stock rods, before spending the money on rebuilding them.
Check out some of the lower priced forged a-beam rods. They are stronger than stock and most come with ARP bolts and they’re brand-new no miles, no wear and tear.
I believe I can get you a set of a-beam forged rods for $269.99. Cheap insurance.
Shoot me an e-mail or pm if I can help. Advice is free. Ask for Harold
Littleredz in particular IT IS THE SAME FRIGGIN BLOCK just machined for more bolts.
By the time you are actually exeeding the 2 bolts capability anyone who HAS DONE RESEARCH would decide on billet 4 bolt conversion not the factory 4 bolt.
Even on the gen1 blocks there is some debate about the 4-bolt blocks additional machining actually weaking the web the LT1 block does not have that problem just an example of how more bolts does not have to mean stronger but you guys seem to buy right in without even a clue as to the facts.
If you are having everything balanced, look into line boring the mains to relieve crank stress; it usually runs around $135-$150 for the work. I'm in the proccess of building my short block right now using the Weiscos, Eagle SIRs, and the factory crank. The trick is in find a good machine shop having everything done correctly and bringing your clearances down. Don't skimp on $1000 worth of parts/ work; you'll end up spending twice that on the next rebuild because of catastrophic failure.
As for my setup, Summit has a kit with Pistons, Rings, Bearing, gaskets, oil pump, everything you need for a rebuild for $540. So $500 for the pistons is still a big jump. This is a po' boys hot rod. I didn't really want to do the rebuild but I had a problem. I polished the crank myself and mic'd it and it's in perfect tolerances for a .001 under bearing. If anyone has priced the gaskets they'll understand why the kit is such a great deal. O'Rielly's wanted $310 for JUST gaskets and pump.
I'm trying to get out cheap. Just a balance and bore on the block. Throw it back together and pray.
ANYONE NEED METRIC RINGS?
