new combo
Old Nov 29, 2005 | 10:41 AM
Juicedz's Avatar
Default new combo
Does anyone know what kind of gains I could see. Last time I dynoed I had untouched afr 190's with 2.02/1.60 valves, zz-409 cam(226/226,112 lsa, .554/.554) 52mm t.b. , stock 24lb injectors and a untouched Lt1 intake. Now I have my worked afr's by Lloyd with 2.055 valves, cam by Bauer Racin (24x-24X) 10x lsalift in the 600 range,58mm t.b, 37lb injectors, and a ported Lt4 intake. Also will I see a decent gain with the nitrous since I am running a spllit duration cam compared to my single pattern? (200 shot)? thanks guys
Old Nov 29, 2005 | 07:07 PM
Quickshotkimber's Avatar
I would expect you to run 10.5 or better N/A with that setup.
Old Nov 29, 2005 | 11:32 PM
Juicedz's Avatar
I was thinking around 11.5 w/ my 28" tire , your setup seems to be more stout than mine
Old Nov 30, 2005 | 04:28 AM
How is that. You have more cubic inches, better heads, better intake, and a cam that is at probably bigger than mine. Do you have the th400 installed that is in your sig?
Old Nov 30, 2005 | 07:01 AM
Juicedz's Avatar
yeah it is installed, what does your car weigh and what drivetain setup dol you have?
Old Nov 30, 2005 | 11:07 AM
T/ALT1's Avatar
I would say low 11's to high 10's shouldn't be a problem but not everybody knows how to make cars ET well. Depends on tuning, suspension, weight and weather plays a big part also. I wouldn't call 358ci much more that a 350 huh? There are alot of tricks to getting a car to run waht it's capable of with X amount of power. Goodluck and I will be in the 10's with my new Trickflows once I get it lined out and to the track. Later Clint
Old Nov 30, 2005 | 02:24 PM
Juicedz's Avatar
clint, we have pretty similar combos. What tire pressure do you run? what rpm do you launch at? shocks? size of converter?
thanks
Old Dec 1, 2005 | 10:41 AM
T/ALT1's Avatar
I am running a 3,800 Vigilante that is tight and setup for n2o. I usually run 14-18psi depending on track conditions and I have Hal QA1's up front and all the rest is stock suspension. I need an aftermarket torquearm, rear shocks and have the suspension set but don't have the cash to do all that right now. Later and Goodluck Clint
Old Dec 1, 2005 | 12:27 PM
Juicedz's Avatar
I know I'm not dyno racing, but how much rwhp do you think I can pick with this new combo guys?
Old Dec 6, 2005 | 06:10 PM
NX_CaGEdApE00's Avatar
get a tune from futral.. JuicedZ..... u will run 10s... N/A...
Good Luck
