How big can we go
How big can we go
I know LS1 cams can be found way over the .600 lift range. Well what about our LT1's, how big of lift on a cam can be found. I think the biggest i have seen is right around .550 area.
Originally Posted by sssalah
2 very popular of the shelve cams the CC306 and GM847 have lifts more then that (0.55), with 1.7 rockers their lift will be in the 0.6xx range. Cams with lifts as high as 0.672 can be had from comp and that's on hydraulic roller lobes, with mechanical rollers higher lifts are available.
Never heard of 1.7 rr's on an LT1
Originally Posted by blkchevyz
i have 600 lift on mine and i still had plenty of piston to valve clearence.
just make sure your heads will support it
Let me guess, only the Head company (i love that word, head) will know what lift their heads can take?
There are a couple of GTP grinds that are right at .600 lift.
well i put harland sharp 1.65 ratio rockers on my heads all im running is a hotcam i had them p&p and when they were on the flow bench i had the guy that was porting my heads check the retainer to guide clearence at max lift which was .621 when the retainer hit the valve guide if you wanna go any higher than that you have to machine the valve guides down or go with .100 longer valves now on the piston to valve clearence i have no clue i ran the 1.65 rockers to get me closer in the area where my heads were flowing and before you ask why i ran such a small cam i live in cali and wanted to pass smog with no problems
