32valve LT1 Progress...
Old Dec 17, 2005 | 08:20 PM
The Big Show's Avatar
Originally Posted by METALBEAST
How in the hell did you get those heads to work on an LT1 block? Kudos and more Kudos! What are those heads from?
A few years ago the company made a few sets for LT1's so it's actually a reversed cooled head and not something that was converted.
Thanks for all the well wishes guys. Let's see if this thing lives up to the hype....
Old Dec 18, 2005 | 12:11 PM
Shon Herron's Avatar
Nice!
Old Dec 18, 2005 | 01:45 PM
LTSpeed's Avatar
Yeah, they quoted me a set a few years ago for $5,000 IIRC, but that was just for the heads. As I'm sure you know, it takes a lot more $$ and sweat before they're ready to run.
I can't imagine running these things without either an old school distributor or a crank triggered ignition setup. I suspect they'd hit the rev limiter before you could get back off the pedal...
At what point is it not an LT1 anymore?
Old Dec 18, 2005 | 03:03 PM
Depends on who you ask.
Old Dec 18, 2005 | 03:32 PM
PipesTA's Avatar
That is damn sexy.
Old Dec 18, 2005 | 03:45 PM
Keep in mind they make 3 different series of these heads and the series with the smaller ports could probably utilize the stock LT1 intake. Although...I originally was going to use a stock intake until someone stole it...
Your exactly right tho on the distributor. I wanted to turn 7K rpm and I knew the opti's reliability up there is non-exsistent so it was a no brainer for me.
I'm with Shon on your last question. As far as I'm concerned, the reverse cooling makes the LT1 what it is. Since you can cover the opti hole and run a regular distrubutor an ignition setup shouldn't decide the designation but no other block cools the heads first from the factory besides the LT1.
Old Dec 18, 2005 | 06:28 PM
buffman's Avatar
Out of curiousity did any other manufacturer use reverse cooling? I thought someone told me the HO 302 in the Fords did?
Old Dec 21, 2005 | 08:50 PM
McTullis's Avatar
Gonna be slow.
Old Dec 21, 2005 | 09:57 PM
N20Dave's Avatar
Looks great Bobby. I can't see those pictures enough times. It is gonna be wicked. 700+ will be no problem.
Some advice though...When it's dyno'ed, take some valium with you. When it hits 8000 you'd swear the rods are gonna come flying out. Ask me how I know. They took mine to 8800. I had to turn and walk away before it was over.
Old Dec 22, 2005 | 02:07 AM
TwoFast4Lv's Avatar
About damn time!
UB better start warming his up!
SB2.2 baby power to ten if it holds
Old Dec 22, 2005 | 03:37 AM
SmokeShow99SS's Avatar
"The unique valve gear arrangement made possible by Arao Performance's patented head design (US Patent #5,007,387) allows rev's to over 9000 RPM without use of exotic valve train parts or freakish valve spring loadings."
Thats nuts!!! when i first saw the pics i thought they were LT5 heads. Guess i was wrong.
Now you have to have someone make some clear valve covers to show those badass heads off.
Old Dec 23, 2005 | 01:28 AM
  #32
N20Dave's Avatar
[QUOTE=SB2.2 baby power to ten if it holds [/QUOTE]
I did it the easy way..we're talkin 32 valves of mayhem here.
Old Dec 23, 2005 | 11:14 AM
  #33
SStrokerAce's Avatar
I wish he could, and so does he!
OldSStroker is still working on the design for the rocker arms on UB set. WE have to make some guides and do some work to these heads to get some bad *** flow numbers like Bobbys. He'll end up with a 396 like Bobbys setup when we are all done, except his LT1 is going in a '71 AMC!
I'm still interested in the results Bobby. Keep us informed!
Bret
Old Dec 23, 2005 | 01:16 PM
  #34
Boshaft's Avatar
Looks like a nice setup. Reminds me of an LT5 head also.
Old Dec 27, 2005 | 09:43 AM
  #35
Now thats something different I hadn't thought of...hrmmmm
Just waiting on lifters boyz....
Old Dec 27, 2005 | 09:45 AM
  #36
LOL...I asked my engine builder how hard we were going to turn it on the dyno and he looks at me and says, "Until it stops making power"....man did the cheeks ever get so tight. I'm so scared this thing is gonna blow up. LOL...
Old Dec 27, 2005 | 10:24 AM
  #37
Old SStroker's Avatar
Two 94 gm intake valves and two 90 gm exhaust valves and the associated springs and retainers make me think high rpm is going to be a significant challenge especially for the pushrods and the rockers. I'd really like to keep the revs well below 7K if it were my engine. The potential flow/curtain area should allow a very fat area under the hp & torque curves throughout the usable rpm range.
The 9000 rpm claims don't seem justified after examining the hardware closely. Of course, I'm a conservative kinda guy when it comes to things mechanical. I'm impressed with 10,000 rpm Cup valvetrain parts. A few ideas might translate well to the Arao heads.
Old Dec 27, 2005 | 11:13 AM
  #38
BizZzatch350's Avatar
Moderator
If the block still says 327 on the side its still an LT1
Old Dec 27, 2005 | 11:38 AM
  #39
I completely and totally agree with you OldStroker. Have you guys actually called the manf. and talked to him? He will try his hardest to convince you otherwise. He goes into talk about about the layout and how the design takes the weight off the valve so then I ask him how is the lifter controlled and he doesn't say much. Thats why I said I'm so worried about blowing this thing up. I honestly won't let him turn it much more than 7K if it gets anywhere close to the numbers I'd like to see. I'd much rather see the motor stay together for a while but after dropping the coin on these lifters it will definitely see at least 7K
At least UB's heads had GM parts in it. My heads were a frankenstein with parts from different things like Volkswagen springs (supposebly high performance ) and some type of retainer I'm not sure of. Valves look okay but I ditched the springs and retainers and put on some 941's with titanium retainers to try and get as much weight off this thing as I can. Pushrod angles are pretty screwy as well as I'm sure you are aware of and that doesn't sit so well with me which was one of the main reasons I decided to stay hydraulic instead of solid. We were going to have to resign the entire lifter area in order to get a solid to work and that wasn't cool.
Old Dec 27, 2005 | 11:47 AM
  #40
Tell me about frankenstien..... I'm using Ferrea valves made for Nissan motors. New valve guides and a good amount of port work, and probably throwing some beehives. Oh and OldSStrokers new shaft mounts.
I think we're going solid on them.
Bret
