anyone have a caprice lt1??
b bodys are about 1000lbs heavier and that makes them about 1 sec slower in a 1/4 mile a strong running b body should see 14.8 no problem.
They also come with Iron heads instead of aluminum on fbodys/corvettes
91-93 Caprices used TBI 305 and 350 motors. The most powerful was 205hp.
94-96 Caprice/Impala SS/Buick Roadmaster/Cadillac Fleetwood. used Gen2 motors. the base motor is a 265cid "L99" baby LT1. It made 200hp. Then the LT1 was optional. 350cid iron heads that flow around 230cfm, a baby 191/196@.050 111LSA .418/.430" lift cam. It was rated at 260hp and 330ft-lbs stock. They usually dyno 215-225rwhp stock. The bottom end is the same as F-body LT1s though. All had the 4L60E transmission. L99 cars had 3.23 gears and LT1 cars had 2.93s (I think) and 3.08s. Most weigh 4200-4400.
We've got a damn good ET Page that shows the details of over 300 cars.
http://dan.esteban.com/impalass/ReturnTopET.asp
Ok, some cars are listed many times, but each with a different timeslip. The list starts at 15 flat, but these cars usually run right around that bone stock. Mine went 15.2@92mph stock. Without changing the opti, plug wires, or even valve springs my car has run 12.971@102.63 with a 1.709 sixty foot time in damn good weather.
Even though these cars are heavy pigs, they do handle well. There are modifications that allow them to pull over 1g in the corners.
http://64.65.63.61/forums/showthread.php?t=416243
Heads on this 383 are aluminum from a Camaro.
Like was already said the bottomend is identical as is the intake, the b-body motors got a little different cam and the iron heads with most accept flow more than the 95 and earlier aluminums. This is attributed to two things one they were designed a year or two later and two the larger chamber does not shroud the valves, not a huge flow difference. The iron heads also have pressed rocker studs as opposed to the screwin of aluminum. Look at what the bolton cars have done in the link Cheston posted there are tabs on top so you can make it highlight different classes very informative site.
Advanytages these things have at the track is they hook well even with me on street tires when I was running 14 second times most LS1 cars were looking at my tailights till past the 1/8th and we have a full frame and 8.5" axle no stiffening necessary and the 8.5" survives 10 second runs.
Mike Harris currently number 40 on the list Cheston posted went 11.8 with home ported irons on a home built 383 with a TINY Comp 501 cam. Look around that page and you will see some very fast cars running the irons, the only reason you don't see more is because people do not bother to try working with them the guys that do though get good results. So do not feel you have to buy alumuminums to get performance.
stock engine w/ F-body MAF, 52M TB, 1.6RR, 160 t-stat, Accel 300+ box
stock trans
Bryan Herter OBD1 program
SLP headers
export pipes
Dynomax catback
2800 Edge TC
alum DS
3.73
SSRI CAI
275/50/15 M/T DR's
This car also has 138K original miles and the car is not stripped...yet.
....it is important though
