stroker times?
Old Feb 16, 2006 | 12:57 PM
98vortecbw's Avatar
Default stroker times?
what would a 383 stroker lt1 run with no mods AT ALL. not even exhaust? its a m6
Old Feb 16, 2006 | 01:02 PM
SAPPER's Avatar
Damn Guy, tryin to get that post count up??? LMAO
There are too many variables. A stroked motor (383) with a bigger cam may idle perfect, the same cam in a 350 will thump. If it is stroked, it could be a 383, 392, 396, 409?????????? there are endless possibilities.
Old Feb 16, 2006 | 02:03 PM
Badazgt's Avatar
it would prolly not run that much lower times w/ a stock H/C/I. The point of a stroked motor is to increase air and without the supporting mods it'd flow almost like stock
Old Feb 16, 2006 | 03:04 PM
blkchevyz's Avatar
you would get more power putting a set of headers on then you would with a stroker put together with stock parts.
Old Feb 17, 2006 | 07:58 AM
lt1taracing's Avatar
when i blew my stock mtr. a couple years ago i built a 383 but everything else was stock 93 a4,3.23 gear. it had ran 8.9s in the 8th before and it went 8.2s after.
Old Feb 17, 2006 | 06:11 PM
it also raised the comp. ratio about a point running flat tops. thats another four percent power gain. the big gain is torque. you can always add the bolt ons later. headers and exhaust picked it up another .3-.35 tenths in the 8th.
Old Feb 17, 2006 | 10:35 PM
A Traumatized Mind's Avatar
my buddy has a 94 Z28 with a 383 kit from eagle. He ran a 12.8 on a street tire. he has 3.23 gearing
Old Feb 18, 2006 | 01:35 AM
StripedZebra's Avatar
Guy in my local club has a 383, EVERYTHING else is stock, and he put 270 somethin at the wheels on the dyno. Thats probably the most expensive thing for the worst gain, im sure.
Old Feb 18, 2006 | 07:46 AM
i eventually changed to a 3.73 gear and saw no improvement. swapped to a turbo 350 and convertor and picked up .5 in the 8th.
