93 Octane???
Old Mar 11, 2006 | 05:07 PM
Red97Z's Avatar
Default 93 Octane???
Ok, right now, with the mods in my sig, i'm running regular gas, 87 octane. Is it save with the added compression from the LT4 heads to run 93 or a higher octane than what i'm running now? Also, will I get more power from it? thanks
Old Mar 11, 2006 | 05:29 PM
Cchris1109's Avatar
oh hell yes you will...
i would be safe and do 93 further on even if its stock, a cleaner more efficent spark is going to save you wear and tear on your engine.
93 always!!
Old Mar 11, 2006 | 05:32 PM
LTSpeed's Avatar
I can't believe you're not running 93 minimum right now. Even stock Z28's were supposed to run 93!
Old Mar 11, 2006 | 05:38 PM
Cchris1109's Avatar
you are going to feel a big difference if you put in 93 octane with those mods and 87, thats like feeling 50 percent of the power!
Old Mar 11, 2006 | 05:44 PM
slowmofo's Avatar
93 is what there supposed to run on stock..... Car will feel quicker with 93
Old Mar 11, 2006 | 06:08 PM
the_merv's Avatar
Veteran: Air Force
Mine won't even run on 87, and that was before the cam....
Old Mar 11, 2006 | 06:09 PM
JustAnIlluzion's Avatar
91 min.
Old Mar 11, 2006 | 08:40 PM
infinitebird's Avatar
Uh, yeah. A lot safer that running 87.
Old Mar 11, 2006 | 08:47 PM
smoknta's Avatar
Mine ran like crap on 87 octane. I accidentally put that in it the first day I got it. I was so used to putting 87 in all my other vehicles. I would not recomment running anything other than at least a 91.
Old Mar 11, 2006 | 08:56 PM
94Z396's Avatar
My stocker spark knocked when i put 87 in it one day, that was the last time for me lol.
Old Mar 11, 2006 | 09:41 PM
ls1charged's Avatar
first of all, personally i would never put anything lower then 93 octane in my car.
Old Mar 11, 2006 | 11:39 PM
Sgt. Spuds's Avatar
Shirley Temple Drinker
My car pings with stock internals with 87
Old Mar 12, 2006 | 08:47 AM
96capricemgr's Avatar
Octane does not make power, octane resists detonation and 93 may be what most of you run but that is also probably the breaking point for octane on a stockish motor, more octane beyond that even with tuning and you could LOSE power.
Red97Z, I don't see tuning in your sig, if you haven't gotten at least a mailoder tune that has to be a priority. If you do have tuning what did the tuner tune it for?
Everyone likes to talk about how aluminum "allows"(more like requires) more compression than iron and often say one full point, the iron head LT1s are 10:1 bone stock and tuned to run 87 octane, I fully believe an aluminum head motor could easily run well up to 11:1 depending on cam and tune on 87 octane. Now before you say something stupid like the octane is the reason for the high HP rating on the aluminum head motors it may be a part of it BUT the big thing was that motor was put in a heavier car and was much better matched to that car than an f-body motor is, it is also rated at a higher peak torque at a lower rpm even though it has less compression and 87 octane tuning. The guys that have pushed the bolton b-bodies have topped the 300rwhp mark so don't mistake it for detuned.
Old Mar 12, 2006 | 09:40 AM
BlackBirdWs6Zzz's Avatar
93 octane is expensive but if you have a trans am with mods you shoiuld be able to afford it
Old Mar 12, 2006 | 11:40 AM
Red97Z's Avatar
wow thanks for all the replies, it was weird that my car was running fine on 87 and saving me a little money, but with all your replies, i'm excited to feel the power at my next pump stop!
Old Mar 12, 2006 | 12:10 PM
Wether you feel power will depend on the current tuning. What does it have?
Old Mar 12, 2006 | 12:19 PM
Red97Z's Avatar
no tune as of yet, i plan on sending it to pcmforless after my cutout is done
Old Mar 12, 2006 | 12:59 PM
Octane is the least of your problems then, bet a tune at this point gains you more than the heads/cam did. The money you spent on the TB or MSD would have gone MUCH MUCH further tuning it right. Reprogramming is a HUGE part of modifying a computer controlled car.
Old Mar 12, 2006 | 01:04 PM
GIZMO's Avatar
You should have been running super from day one. Note that detonation is not always audible. When you do any kind of modifications a correct tune is a must. Detuning to run 87 octane is the wrong answer. Caprices got a tune for 87 octane for non-performance reasons.
Daren
Old Mar 12, 2006 | 04:29 PM
the_merv's Avatar
Veteran: Air Force
IMO, I consider 87 crap gas for an every day beater or somethin small. Who would want to run it in a Perfromance Engine, with alot of expensive parts... I ran 105 one time at the track, it was a little more peppy than usuaul.
