LS1 Lid on LT1
Where did you get the piece that covers the radiator, I know it is an ls1 style. IMO it looks much better than when people cut the lt1 style shroud to make the lid fit. Overall how much did the conversion cost you and where did you get all the parts from.
Thanks
Lower air box, lid, filter, smoothe bellow and relocate the IAT to the other side you'll see it on the box. Make sure to get a 99 lid or newer or you'll have to plug up another hole on the box if you don't. I also did the FRA cutting the box, the FTRA and super scoop underneathe for more air. But I also got all that used too.
That's it. The Best V8 Stories One Small Block at Time
I have seen a car gain on the streets with this mod over a lt1 CAI so i know it helps out, although no dyno numbers to back it up.
The reason i did this is because if it can help a ls1 then it can help a lt1. I have a camaro so i didn't use the lt1 ram air that come on the ws6's.
Stock
Alley Speed LS1 Lid Conversion
Whats up Neal? How is is the lt project coming?
I know that I could use the FTRA but I would rather do the WS6 Radiator shroud if at all possible.
IF I was able to switch out to the LS1 lid from a 98+ WS6 w/ ram air
would my 97's ram air hood be functional with a 98+'s ram air box assembly?
Just let me know what steps I need to take
Thanks. I have seen a car gain on the streets with this mod over a lt1 CAI so i know it helps out, although no dyno numbers to back it up.
Stock
what did you make the radiator support out of?
