over heating
Old May 27, 2006 | 06:40 PM
NosFed99z28's Avatar
Default over heating
my dad has 95 corvette driving it down the road its fine but once you sit for a minute or so it over heats and on real hot days it will overheat with the air on while driving down the road what can he do to stop this or help
Old May 27, 2006 | 06:55 PM
96 LT-1's Avatar
Bad Seller Warning!
are vettes the same as birds???? do they have the plastic air dam under the radiator did he take it out or crack it?
Old May 27, 2006 | 06:57 PM
96_TA's Avatar
My girlfriend had the same prob with her '96 Sunfire. I believe it was her t-stat or something to do with it.
Good luck.
Mike
Old May 27, 2006 | 08:45 PM
yes he has the air dam but its there and not craked
ttt...
Old May 27, 2006 | 10:42 PM
Wyoming T/A's Avatar
replace thermostat,if it still does it, it could be a plugged radiator
Old May 28, 2006 | 01:49 AM
the_merv's Avatar
Veteran: Air Force
Thermostat is where I would start.
Old May 28, 2006 | 04:07 PM
Azthrei's Avatar
I'd say it's gotta be the thermostat, or the fans aren't turning on.
Old May 30, 2006 | 01:09 PM
already replaced the thermostat
Old May 30, 2006 | 01:12 PM
BlackBirdWs6Zzz's Avatar
Check to see if fans come on, check relays, check computer
I got a manual fan switch myself.
Also, one fan is supposed to come on with the AC. I don't know if the 95 vettes have dual fans or just one.
Also make sure it's not your pump. Do A coolant flush
