GM847 Cam Driveability
Old Jun 16, 2006 | 01:38 AM
2fast97Z's Avatar
Default GM847 Cam Driveability
please someone that has this cam jump in...im looking to use this on a newly rebuilt stock cube stock internal ported heads and intake car with all bolt ons, 30# injectors, tune,AS&M 58mm and msd digital 6...will this work? how is the idle and loping on the 847 and how is the power range and what are you running similar cars dynoing at
Old Jun 16, 2006 | 04:43 AM
slowmofo's Avatar
Not sure what mine runs or Dyno's yet, My 30# and tune go in today, I do not have a MSD or AS&M 58mm TB though....I am going to the track tomorow, so I will see what it does in the hell heat. As far a drivability, I drive mine every day. It not great on gas around town, but still good on the highway.
Old Jun 16, 2006 | 07:30 AM
-PEPE-'s Avatar
Do an 847 search you'll find a ton of info, I recommend a custom grind, I ran the 847 w/1.7rrs and all the boltons, stock cubes for a year or so & dynoed 373 & ran 12.6 1/4 ET. Badass cam, still recommend a custom grind though.
Old Jun 16, 2006 | 09:56 AM
IllusionalTA's Avatar
Originally Posted by BRETTINATOR
12.6 1/4 ET.
i wouldn't be publicly posting that sorta info....
Old Jun 16, 2006 | 12:32 PM
-PEPE-'s Avatar
Why would I care? I don't have the setup anymore...
Old Jun 16, 2006 | 12:34 PM
Old Jun 17, 2006 | 12:47 AM
KWIK WS6's Avatar
I have an 847 and just got 400rwhp with it. Could make a little more but ran out of fuel pump at 5k(stock pump) still spin's to 6800 but goe's lean.
Old Jun 17, 2006 | 03:23 AM
TwoFast4Lv's Avatar
Damn Brett I would hope that new combo makes more power then that
I went 11.75 with that cam
Old Jun 17, 2006 | 05:14 AM
LT1BRN's Avatar
can you tell us mor about the setup, mod list, cubes, Heads.
PM if u dont want to post please.
Old Jun 17, 2006 | 07:40 AM
-PEPE-'s Avatar
damn Ellis, that's awesome you got almost a full second better than me with the 847, maybe it was the driver
The new setup is gonna put it down hard, the new chassis/suspension is going to hook it up good I believe
Old Jun 17, 2006 | 08:42 AM
KWIK WS6's Avatar
80K miles stock short block.LT4 head's gasket matched port's,58mm TB,pacesetter LT's,cloy's doubleroller,electric WP,cut out,4:10 gear,
Old Jun 17, 2006 | 11:42 AM
TwoFast4Lv's Avatar
Yea it ran pretty well for a 350 just was not as consistant as I wanted. By summer it had slowed down to 12.20s.
It's not offten we get Texas Weather here...and when we do you better hope the track is open
We just had that cam in a 396 and it made 437RWHP for a loss of 11hp over the cutom cam we were using. With the 238/245 cam the car made 448hp/453tq at the rear through an Auto and 12 bolt. Next we are going to have Bret cut a cam for it and try again.
BTW we played with it on the dyno with the 847 and managed to pick up over 30 RWTQ with just a little timing and fuel
This is the second Shop car. 396 C.I. ,LE AFR 210s ,Hooker LTs ,SSEFI proto Intake , and a Stock opti sytem
Good luck!
OH yeah one last thing! Last time we were at the track with this car it was yanking the wheels with 17 inch ET Street Drag Radials and a STOCK TQ arm
Old Jun 17, 2006 | 02:38 PM
-PEPE-'s Avatar
Yea it ran pretty well for a 350 We just had that cam in a 396 and it made 437RWHP for a loss of 11hp over the cutom cam we were using. With the 238/245 cam the car made 448hp/453tq at the rear through an Auto and 12 bolt. Next we are going to have Bret cut a cam for it and try again.
847 is a baby cam for a 396, that's pretty impressive, they planning on swapping the other cam back in or go solid, what's in the works?
Old Jun 17, 2006 | 03:24 PM
TwoFast4Lv's Avatar
Yup we already have the other cam back in and we are going to have Bret design a pretty nasty HR for it. Jim wants 475 Rear wheel or more out of it
