leaking oil
However, the oil is likely coming from the seal behind the distributor. The opti has a round protrusion that mates with the cam, this protrusion has a seal in the timing cover it seals to. Its common for that seal to wear out.
The dist. and water pump must be pulled to fix it.
Go get a dist seal, if you go to advance auto or autozone, you'll have to buy a complete gasket kit for the timing cover to get that seal.
