cam help
Old Jun 24, 2006 | 08:18 PM
96 LT-1's Avatar
Bad Seller Warning!
Default cam help
how much HP would i expect out of this cam CAI and LT pacesetters full race and true duals with an x pipe and 2 12" bullets
CAM-@.50 its 232/244 .515/.545 cut on a 113. Its a custom grind from Xtreme Horsepower.
Old Jun 25, 2006 | 11:27 AM
96 LT-1's Avatar
Bad Seller Warning!
noone?
Old Jun 25, 2006 | 11:31 AM
jrp's Avatar
jrp
SN95 Director
https://ls1tech.com/forums/advanced-engineering-tech/396223-what-forum-please-read-before-posting.html
thats why....
Old Jun 25, 2006 | 04:55 PM
96 LT-1's Avatar
Bad Seller Warning!
someone ??
Old Jun 25, 2006 | 05:04 PM
dhdenney's Avatar
Ballpark 350 at the wheels through M6. It's just a shot in the dark. People don't like to answer such general questions.
Old Jun 25, 2006 | 05:22 PM
zlover129's Avatar
yea, thats a lot of cam for no headwork too
Old Jun 25, 2006 | 05:53 PM
Ari G's Avatar
Port the heads and youīll get 20 easily and bigger valves 202/160 with it and get even more and better milerage
Old Jun 25, 2006 | 06:18 PM
96 LT-1's Avatar
Bad Seller Warning!
Stage 3
Stage 3-port work with flow sheets
Ferrea 2.050 Stainless steel-swirl polished intake valves
Ferrea Stainless steel-swirl polished exhaust valves
Comp Cam HP Bee Hive valve springs
Comp Cam retainers (add $100 for titanium)
Comp Cam locks
5-angle valve job-set valve stem heights-set spring installed heights-
bronze guide liners-surface-pressure test-new valve seals-
Completely assembled ready to bolt on.
Complete Stage 3 - $1799.99
would that be a good head / cam combo??? how much HP would i be expecting with that came mentioned above and those heads i just sent. they are port pros stage 3
Old Jun 25, 2006 | 09:32 PM
Ari G's Avatar
you match the cam with the heads and there flow numbers not the other way around
Stage 1,2,3,4,5,6,7,8 donīt tell anything,flownumbers at each lift tell the whole story and how to grinde the cam with the heads
Talk to Lazercams,they are good and inexpensive
My cam is pulling hard from 2500 to 7000rpm
