whats needed to take stock lt1 to 400 hp
Originally Posted by camar0corey
how much is port matching the intake manifold worth?
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
Originally Posted by James Montigny
I paid $200 for port matching (to heads), 58mm bores and appropriate porting on the inside. Total of 3lbs of material removed. ![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
I've always done the manifold when I do heads, so I've never done a
comparisson dyno. It just seems to me that spending a few $K on a project
then leaving such a big restriction to flow in the intake is a bad idea.
Especially when it can be resolved so inexpesively.
Kinda like installing LTs and running them into a stock (GM) catback.
Oh yeah I understand. I did the same thing the intake with the heads, heck far as I am concerned having the head porter do the intake is the only right way because if done seperate and the intake ports end up being bigger anywhere than the head ports the shelf created will be very bad for flow.
