TURBO OR SuperCharger
2200 is decent for a used vortech kit. what kit is it and how many miles are on it?
i have a s trim kit for sale, pm me if interested
brook
Of course both are tunable and can be changed around some, but I would get the LT1 all new forged parts to handle the boost, then Procharge about 9 LBs on her!
turbo and supercharger cost abotu the same when you factor in certain things. Like with a turbo you have a full exhaust and everything because that is what the turbo runs off of. So add exhaust in to the supercharger equation to level the playing field.
You will probly spend more on the turbo setup in the end. but you will be much more happy with it i think.
j/k But yea, you are right.
1. turbo set up will cost more.
2. on the same boost level (say 6 psi) you will hit full boost at a lower rpm with turbo setups with the right size of turbo giving you better midrange touque and hp. (3000 vs. 6000)
3. with the turbo you can adjust the boost on the fly.
4. supercharers sound bad *** though, althoug some prefer the turbos spool and blow off.
5. supercharers are much more simple to set up than turbos. (excluding sts)
6. boost costs more than what you plan, so figure a bit more in. in some cases a lot more.
what would I prefere after having both, turbo comes out on top. even though my s/c would launch harder than my turbo because I have no two step, but I am still quicker with my turbo setup.
Tony.
Tony.
You can have alot of boost and/or N20, but if youre tuned to not push limits, it should be ok.
Some guys on here have pushed the limits and have been perfectly fine, others had it happen vice versa, where something like a faulty install or improper plug caused detonation.
IMO, I would re-do the engine completly and install forged internals, then put on the S/C
