Advice needed on EGR removal.....
there are no advantages. The only reason to do it is if your EGR system is rendered inoperable by exhaust modification. It doesn't gain you any HP and will actually make you run very slightly more lean.
to be honest i think you actually loose gas mileage.... by 2-3 MPG.... but it does look alot cleaner... and most people do it cuz the their EGR's have failed... so its an easy fix...
I agree with the " cleans the bay " post and the " if you tune it to ignore / mean tune " it can equal the MPG if it doesen`t beat it, that and you start the whole shave every oz you can wile having one less thing to fail.
