Best Nitrous Pistons
Old Aug 30, 2006 | 02:51 PM
Chevydomination's Avatar
Default Best Nitrous Pistons
Hey guys did a search and came up with nothing. I was wondering about pistons since I'm building a 355. So far I have eagle 6" H beam rods and a GM forged crank for my LT1. Since this will be a nitous motor I was wondering what pistons to go for. I was thinking of Probe's SRS pistons since they handle a 350 shot of juice. So what do you guy's think??
Old Aug 30, 2006 | 05:10 PM
artic's Avatar
SRP made by JE pistons
Old Aug 30, 2006 | 06:33 PM
They are good pistons but only handle a 200hp. While the probe handle 350hp and are made of 2618 material. SRP's are 4032 I belive, the 2618 I think is stronger.
Old Aug 30, 2006 | 08:15 PM
travie319's Avatar
WTF
Old Aug 30, 2006 | 08:35 PM
Originally Posted by travie319
WTF
Forged of 2618 t-61 Aluminum alloy for the ultimate strength and fatigue resistance is the material in the pistons, this is from probe's web page. I heard alot of people say if going to use alot of nitrous that the 2618 alluminum alloy forged piston would be the best choice because if it's strength.
Old Aug 30, 2006 | 09:16 PM
OutlawZ's Avatar
Call JE and get a custom slug done..... My flattop custom JE nitrous pistons have a 300 top ring land, gas ported with reduction grooves..... Can handle a 500 shot..... They're based on a pro mod design only made for a 4.030 bore and 6" rod....
It really depends how much sauce you plan on runnin and then have JE build you a set to your builders specs...
Old Aug 30, 2006 | 09:36 PM
machinistone's Avatar
^ +1
Call JE for some blower/nitrous pistons.
Old Aug 30, 2006 | 09:39 PM
rocket22's Avatar
JE hands down
Old Aug 30, 2006 | 11:48 PM
streetwarrior96's Avatar
JE
Old Aug 31, 2006 | 12:10 AM
JUICED96Z
Guest
Posts: n/a
Yep,
JE can make a custom piston for you to handle pretty much anything. I just found some JE's off the shelf that will handle 650hp. Beyond that I am pretty sure is all custom. From what I hear JE also has outstanding customer service.
I plan on going 500 shot (more then one stage) or big turbo, more then likley 500 shot, JE for me.
Old Aug 31, 2006 | 01:19 AM
pigpen's Avatar
1 for Diamond pistons - they can custom make anything you want, if they don't have it on the shelf...
Old Aug 31, 2006 | 06:27 AM
NOSARMD's Avatar
+1 for Diamond Pistons
Old Aug 31, 2006 | 09:21 AM
Great, I'll call JE and Diamond a call today.
Thanx guy's
Old Aug 31, 2006 | 09:47 AM
TwoFast4Lv's Avatar
JE SRP Shelf pistons here. $400 and taking crack like it is hooked! Put 28 Lbs of N2O on them last race
Old Aug 31, 2006 | 10:48 AM
JUICED96Z
Guest
Posts: n/a
Thanx guy's
Just remember that no matter how good a piston is, it will not matter if you use crapy rings!
Old Aug 31, 2006 | 12:54 PM
Good point!! any recomendations??
Old Sep 1, 2006 | 06:22 AM
NOSARMD's Avatar
Total Seal AP Series
Old Sep 1, 2006 | 09:09 AM
dhdenney's Avatar
I heard someone mention that the SRP's were just as good as JE's higher $ piston cuz they were a little heavier and have more meat on them. I obviously can't back that up scientifically but you know what I am saying.
