backfire after header install
Old Sep 7, 2006 | 06:00 PM
transambandit's Avatar
Default backfire after header install
just finished my pacesetter install/ory and borla install, i go and start it up and it runs fine, then i give it some gas and i get a backfire at around 5k rpms, anyone have any idea whats causing this? i had to take the pass side spark plug wires off to get some slack so one of them wouldnt touch the header, but i am not sure if i put them back in the right order, would this be the problem?
Old Sep 7, 2006 | 06:04 PM
red95ssclone's Avatar
Excess fuel is being burned after spark is shutoff. This happens alot when cats are removed. Unless it is detonating or studdering then you shouldnt worry
Old Sep 7, 2006 | 06:27 PM
if i tune it to run a little leaner would it get rid of the problem?
Old Sep 7, 2006 | 06:33 PM
itSSlowZ28's Avatar
tuning should do it. someone back me up on this, but i believe lt1's run a tad rich from the factory. if you haven't gotten a tune yet, it'd be a good time to get one anyways
Old Sep 7, 2006 | 07:33 PM
edlt1's Avatar
yeah
double check your order.
Mine popped really bad when I mixed up the 6 and 8 cylinder
Old Sep 7, 2006 | 07:51 PM
-PEPE-'s Avatar
I'm not sure if they run rich from the factory but mine was always rich in stock form, after headers it popped a little till the dyno tune.
Old Sep 7, 2006 | 08:06 PM
okay, can someone tell me the order the plugs are supposed to go into the distributor so i can see if im out of order, my manual doesnt say **** about it, preferably from top to bottom. thanks.
Old Sep 7, 2006 | 08:37 PM
camar0corey's Avatar
top to bottom, 4,6,8,2
Old Sep 7, 2006 | 09:11 PM
the_merv's Avatar
Veteran: Air Force
Here ya go bud..
File Type: bmp
Old Sep 7, 2006 | 09:44 PM
cool thanks guys.
Old Sep 9, 2006 | 12:21 AM
jst's Avatar
jst
What hood is that in your sig?AWESOME!
Old Sep 9, 2006 | 08:55 AM
the_merv's Avatar
Veteran: Air Force
Looks like a beefed up SS Hood..
Old Sep 9, 2006 | 09:18 PM
curlyws6's Avatar
Originally Posted by edlt1
yeah double check your order.
Same thing happened to me... check that first (it's easy to cross your wires up).
