cam sizes
Old Feb 6, 2003 | 06:48 PM
1badblk94TA's Avatar
Default cam sizes
what size cam do yall recomend, i still want good driveabilty becouse it is still my daily driver and i would like to stay with stock tranny and heads (other than springs).is the hot cam kit a good deal or should i stay away from it.
thanks in advance
scott
Old Feb 6, 2003 | 06:54 PM
Default Re: cam sizes
I forgot to add my mods
hooker long tube headers
k&n cold air induction
taylor 8mm wires
3" flowmaster w/dump
Old Feb 6, 2003 | 07:24 PM
The Big Show's Avatar
The hot cam has proven to work time and time again on stock heads.
Old Feb 7, 2003 | 01:17 PM
solid95z's Avatar
Frank Benoit from Houma La. rana 11.4x @ 116 with a Thunder 210/224 cam with stock heads and bottom end. His cam had ALOT of drive ability and idles very smoothly. I love the cam I have. It has proven it'self for sure.
If you are gonna get a cam, I would get the Thunder 210/224 cam.
If you're gonna spray as well, you minght think about the Hotcam or the 305 also.
Old Feb 7, 2003 | 02:37 PM
MEAN LT1's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 1badblk94TA:
<strong> what size cam do yall recomend, i still want good driveabilty becouse it is still my daily driver and i would like to stay with stock tranny and heads (other than springs).is the hot cam kit a good deal or should i stay away from it.
thanks in advance
scott </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Are you a m6 or a a4?
I would get something bigger than a lt4 hot cam. The 305 cam is a good selection but if it were me I would go with a xe-224/236 cam on a 112lsa is your a m6 or ona 114 if your a a4. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Feb 8, 2003 | 08:46 AM
It's completely pointless to overcam a stock headed motor. You have a car that sounds fast and then gets outrun by a lesser vehicle <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Old Feb 8, 2003 | 07:36 PM
Ram Air LT1's Avatar
We put a hot cam in a 95 formula with hooker long tubes, electric water pump, cut out, 4:10 w/stock rear end, stock heads and intake,6-speed, running nittos on c-5 vette rims the car went 12:31@113. After that we pulled the heads and intake off and had a freind port them in his back yard the car went 12:28@116 in colder weather all these pases were made at full weight all interior pieces.
Old Feb 8, 2003 | 10:13 PM
mightyquickz28's Avatar
Like Bobby said, the LT4 HOT cam & kit is hard to beat for the objective you stated and the mods you posted. I had the LT4 HOT cam in my 96 Z28 M6. At full weight (3,650) with SLP headers(suk) and SZ50 Firstone Radials, stock 3:42 gears and the HOT cam, I got 3 passes of 12.8 @ 109 (1.9 sixtes). After adding Long Tubes and ET Streets, I went 12.5 at just under 111 mph. After breaking the M6 and putting in a TH350, every thing else the same I went 12.2 at just under 111 mph. Here's that pass.
http://www.taekwondoplus.org/z28/25.mpeg
