O2 Sensors and racing fuel
Is there anybody that knows of a solution to this. Do they make a O2 sensor that is compatible with leaded fuel? I don't run it straight but it is nice to mix it in once in awhile.
Originally Posted by 96capricemgr
You can get unleaded up to about 110 octane I believe, that would be the solution I would use. You are just talking for the nitrous fuel supply anyway right?
I searched a little while and never could find anything. I torched mine with leaded fuel. Don't know about you but it's hard to find anything unleaded around here. Beechbend just has the leaded ****. Probably have to order in the unleaded.
The Nitrous fuel supply is from the tank. I just added a 3/8 fuel line to the sender that goes all the way to bottom of the tank. It is feed by a Holley Red Pump. So they are the same source.
