LT1 AFR's???
You are exactly what I was talking about those too ignorant to try just pretend it is something wild and mysterious rather than learn something.
tbsimmons, my cam is VERY similar duration and lift to yours and not as tight a LSA as most of the LE/BB stuff I have heard specs on. A friend has a TPIS ported AFR headed stroker LT1 in a third gen and despite the weight disadvantage my car has SOTP is no comparison HP wise, lowend torque with his lighter weight he seems to have me though, his cam is 240/240 and like .56x/.59x with his rocker ratio split. He has some tuning issues I can help him with but I do not think either of us believes they are worth the .5 in the quarter between us at this time. I tried to take it to the dyno but had problems(rod bearings) and the car left on the rollback without a clean run. Threw another stock shortblock under it for now.
I blame the failure on roughly 470-480fwhp on a high milage motor combine with fuel issues in spring that had caused detonation and some metal in the oil at that time, since it stopped making metal once the fuel system was up to par I left it alone and it held for over 5K more miles and I could not even guess how many 12.3-9 second passes this summer.
Also remeber my going with AI was going against the grain, there are A LOT of parts on my car where I was one of the first to go out on a limb and try something a little different. Where I confuse people is when I push RESULTS over reputation, people can not get past a good reputation to see mediocre results hench the popularity of LT4 stuff and AFR.
Since you are accusing me of just looking for a reason to drop names how about Mike Harris, I have never bought a thing from him, he deserves a lot of credit for his car. 480rwhp through an 8" 4200ATI 4L60E the LT1 aluminum heads, LT1 intake, 383 and tranny all ported and built by him cam is a 242/250 off the shelf Crane solid roller. Again see what happens when people actually try.
Lloyd, RacePrep and a whole host of others get great results out of ported LT1 castings as well and IMO the Trickflows would be the aftermarket LT1 casting to play with, I do not know a lot of info on cars that run them from AI but I know of a few spectacular performing b-bodies that run them ported by Chapman.
your gonna go there?
I know dayne still has room for more power, and hasn't done jack to lose weight.... I bet he will break the Heads and Cam b-body record soon.
Daren
And for some of us, running what was given to us from GM is more fun. I like doing more with 'less'. People telling me that something can not be done and then proving that it can be done.
Abare's car is a great example of what can be done if given the opportunity.
When trying to sell a product your going to do some crazy **** that most dont.
In AI's case, they went ***** out with stock castings, most LT1 owners wont do what AI did, that car is more then a ported stock intake/castings.
Most of us cant say the same.
Daren
theres me, waaaaay down at the bottom. class 6, aka the slow pokes.
Mike Harris, that is a little extreme dont you think.
Him, Karl, Glen and Pat can not be compared to the norm.
Anyone that runs those times has optimized a combo, even with a lighter car.
I have talked with Mike on the phone a lot, he does great at car setup, as does the others which I have seen numerous times at strips I fly to back east.
The point I was trying to make is you degrade people for choosing LT4 and AFR stuff.
Is there a better solution, SOMETIMES.
Was there with mine, I dont know, but it seems to be working right now.
On the ET list mine is a 13.48, stock motor, class 6.
The last point to this, if you maximize what you got, you will be fast.
But telling someone they are an idiot for doing so, well no wonder you get under peoples skin.
Your friend with AFR's, I think he has to big of a cam, remember what Harris was running with a 501 cam in a stroker?
Total RWHP is not everything. If you have flat curves, that can be better.
Also on peaks, some do not have the number and live in places that smog is a problem.
Heads and cam record right now is 11.9 at 115, by Karl.
Far as the top cars on the b-body ET page having AFRs as I said the cars that make those heads work have cubic dollars thrown at them, I am a bit more falimiar with those individuals than you and the number 5 car is IMO the most impressivie, yes it is stripped but it is flying for the comparatively tiny amount of money he has into it, out of those 5 that is the only one on stock engine management. One of those times is a car that belonged to a lawyer whos SLOW car was a Viper, he hemoraged money into that thing believe the total was over $90K and today backyard built cars are knocking on his records and one has fallen already.
2 of those are also OLD times before we had as many wonderful options for porting LT1 castings too.
People do not understand how a lot of times it is when cars are newer and owned by folks with LOTS of money that records are set and they stay but as time goes on and folks learn other come damn close to the records for a tiny fraction the cost.
Far as the 375rwhp joke even the most LE faithful will agree my car makes more than that.
I will admit that Dwayne is absolutely crushing me on power right now with his AI ported heads vs my AFR's, but my car has some pretty major issues right now.
Maybe Im wrong, but one thing that the AFR's definitely have going for them is strength. I origianlly bought them with the plan of running a forged bottom end and a boatload of spray. The AFR's weigh alot more than the stockers, especially after alot of portwork on the stockers. The AFR's have a very thick deck. I had walked away from my car and came back 15 minutes later to find the temp gauge pegged. I had the AFR heads checked for cracks or warping. They pressure checked perfect and are as straight as the day they were new. The engine shop that checked them was amazed at the fact that they needed no work at all.
I guess im not arguing or agreeing with anybody. I think Dwayne made a very good choice and is doing very very well with his AI setup. I also think that if the people with the AFR's are happy, thats good too. Everybody has their own opinion and you know what they say about opinions. I say, buy whatever you think you will be happy with (AFR in my case).
BMR/AI.
Everyone that reads this sees it like we ******* hate stock castings and they are shitty. The guy makes great ******* POWER!! But thats not going to happen on a DD LT1, just isnt.
Tony.
the problem is people do not give it time, they just think they need something else.
Abare's car is closer to stock than my car, and I was just bolt ons.
As many 383s that are out there on the street, there should be some nice 475+ combo's running around with stock castings but NOPE. Mediocre (sp) low 400s, why!?!?
Sure would be cool to be sponsor'd that is for sure!!
Tony.
