FAST 90/90 on an LT4?
Old Nov 4, 2006 | 08:13 PM
eLTwerker's Avatar
Default FAST 90/90 on an LT4?
Will a FAST 90/90 go on an LT4? What modifications will I need to do, if it's possible?
Old Nov 4, 2006 | 08:19 PM
JimboManJones's Avatar
Isn't the fast 90/90 for ls1s only? LS1 and LT1 parts don't interchange.
Old Nov 4, 2006 | 08:41 PM
BlackScreaminMachine's Avatar
Internet Mechanic
try it out and let us know
Old Nov 4, 2006 | 09:09 PM
eLTwerker's Avatar
Well, what I'm trying to get at is-what makes the 90/90 incompatible with an LT4. The throttle body's connection to the air box I'm sure can be modified if needed. It's only plastic. The complication comes in with the manifold, I suppose. I'm wondering if anyone who has had a 90mm intake manifold on an ls1 can tell me or show me how it connects to the heads vs. how an LT4 intake mounts. Than I'll know if its worth the trouble. Aftermarket throttle bodies for LT1/LT4s are in the 52-58mm range. Is 90mm too much for the heads to handle? I have GTP ported stage 2 heads, btw.
Old Nov 4, 2006 | 09:38 PM
eLTwerker's Avatar
Never mind, the connection to the heads is at a different angle, plus the intake ports don't match up. Scratch that idea.
Old Nov 4, 2006 | 11:45 PM
BizZzatch350's Avatar
Moderator
If it worked, do you think any of us would have LT1 intakes any more?
Old Nov 5, 2006 | 08:25 AM
Rowdy94's Avatar
I would. Im poor
Old Nov 5, 2006 | 08:57 AM
Honda Hunter's Avatar
I wish we could do what Mustang owners do. The use flanges/spacers to make some manifolds work and line up.
Old Nov 5, 2006 | 09:11 AM
396D1SS's Avatar
alot of duct tape will git er dun
Old Nov 5, 2006 | 09:24 AM
azvforce's Avatar
It absolutely won't work, ever. You can't make it work, so don't even ask. As far as the LT1 throttle bodies being 52-58mm, They are twin 58mm bores my friend, that 58mmx2 in the LT1 tbs.
Old Nov 5, 2006 | 11:40 AM
94z28L's Avatar
if you need more than a twin 58 there's a huge mono-blade set up that AS&M makes
