What kind of oil?
Old Nov 15, 2006 | 10:47 PM
LT1bird's Avatar
Default What kind of oil?
I was wondering what the best kind of oil is for lt1 and ls1 cars? synthetic or not? Is royal puple any good ? thanks
Old Nov 15, 2006 | 10:59 PM
93 blackformy's Avatar
I use Mobil 1 5w30 with no problems
You have to take some things into consideration: mileage,are there any leaks already?..Its up to you
Do a search and see what you come up with
Old Nov 15, 2006 | 11:15 PM
buffman's Avatar
royal purple is a good oil but there are better oils to take into consideration. German Castrol 0w30 FTW
Old Nov 15, 2006 | 11:37 PM
coldkillinTA's Avatar
mobil 1 5w30 synthetic here!
Old Nov 15, 2006 | 11:39 PM
93BlackZ28's Avatar
Mobil 1 5w30 Synthetic
Old Nov 16, 2006 | 07:16 AM
LT1MAN's Avatar
mobil 1 5w-30 full synthetic, changed every 2500 miles.
Old Nov 16, 2006 | 07:20 AM
moserman's Avatar
if you are still on the stock block use 5w30 synthetic, but anyone using a crate motor with aftermarket bearings, the weight of oil will depend on the bearing clearances. i use valvoline vr1 race oil 20w50 for mine, simply because thicker oil will prevent you from spinning the infamous rod bearing
Old Nov 16, 2006 | 11:11 AM
dre2013's Avatar
i use amsoil 10w30 fully synthetic...no problems here, and next oil change it will be the same
Old Nov 16, 2006 | 02:31 PM
buffman's Avatar
oil choice is going to be dependent on too many factors. We can really only recommend oils. and I will tell you there are lot better oils to use on MR LT1 than stupid M1 5w30 and 10w30.. Valvoline 20w50 VR1 stuff is a good racing oil, but not very good for something that gets regular oil changes.
Old Nov 16, 2006 | 02:42 PM
streetwarrior96's Avatar
Mobile 15/50 here
Old Nov 16, 2006 | 04:14 PM
maybe2fast's Avatar
what about the 5w-50 that the Ford GT uses now. I am thinking about using it
Old Nov 16, 2006 | 04:27 PM
LS1 Eddie's Avatar
I keep it simple. Castrol 10w 30
Old Nov 16, 2006 | 06:07 PM
Turbo_6's Avatar
As far as the quality of the base stocks used in synthetic oils, the best out there are Amsoil, Royal Purple, Redline, and Mobil 1, not necessarily in that order. For a high performance application or high stress/high sheer, the synthetics will 9 times out of 10 be better than any conventional...racing oil or otherwise.
As to what weight, that is dependent on climate and also clearances as said earlier. Amsoil has invested quite a bit of money in their own research and also 3rd party research and has published some data showing their oil to be better than some of the other leading synthetics. Do an internet search and you can see some of those results. I currently have redline in my pan, but I think I may give the amsoil a try for a while. I've used both Mobil 1 and royal purple in my stock bottom end before my recent rebuild with good results also. I don't think you can go wrong with any of the above listed if you are running the right weight. Mobil 1 is the most convenient and readily available as well as cheapest of the 4 if that factors into your decision (it doesn't in mine).
Old Nov 16, 2006 | 06:15 PM
buffman's Avatar
umm you forgot mr German Made Castrol Syntec 0w30...
Old Nov 16, 2006 | 07:16 PM
transamtom's Avatar
I have used Mobil 1 5-30 since 18,000 miles,I just did a H/C swap and the cross hatching on the cylinder walls is still there after 110,000 miles.
Old Nov 16, 2006 | 07:19 PM
siniSSter's Avatar
Redline all the way!!
Old Nov 16, 2006 | 07:49 PM
burnzilla's Avatar
As soon as I got over 80K, I switched to Mobil 1 10W30.
I think 5W30 is a little lean for LT1's, but im up here in NY.
Old Nov 16, 2006 | 07:52 PM
buffman's Avatar
both are considered "lean" compard to other 30 weight oils. Hence the reason why Mobil 1 5/10w 30 oils get called "thin" Remember the 30 weight is a range of measurement, not an exact thing
Old Nov 16, 2006 | 08:01 PM
burnzilla's Avatar
First off I want to say I know what you mean, and agree with you. Mobil 1 is known as a good performer... that why I like it
SAE 10W30 and Synthetic 10W30 are exactly the same weight, dexterity, etc... and must pass all the same tests. One is not "thicker", or "thinner" then the other.
There are chemical properties in the synthetic that makes it last longer and provide more slippage/lubrication... thats the difference.
I used to think there was more of a difference until Chip Foose proved me wrong.
Old Nov 17, 2006 | 12:44 AM
Formula350's Avatar
I can't imagine running 0w30. Starts as 30, and when warm is 0w.... I'd fear leaks...
I haven't changed mine yet since I just got the car. I'll probably run 5w30 since it's winter, but 10w30 for the summer. My TPI Bird I just ran 10w30 year round.
