Turbo LT1... figured you guys would like to see... 56K BEWARE
#81
is that an old datsun? i have a s10 thats layed out on 20's now. started bodydroppin it about a month ago and just have to finish the frame horns and body mounts since i moved it back 3/4". it'll be a bad **** once its done.
#83
Well fella's.. its runs... and the turbo starts to scream by 2200 rpms under load. I don't have a tune or anything as of now so I didn't go out and step on it or bring it any higher than that....
Seems to be working out so far. Turbo is getting oil, No exhaust leaks that i know of yet and no smoking. So hopefully i won't need a restrictor. Really wish i had a clear line to put on as a oil drain to make sure all is good but I guess im trusting god (and the fact i know oil is GETTING to the turbo).
But that is the current update... Can't wait now. The turbo comin in is orgasmic!!
#88
Originally Posted by golfcartracerx
2200 RPM spool up vid would be EEExcellent ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Will be towards the end of the week at least till i have any kind of vid. The suspense is killer guys!!
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
#91
Yeah it has been pretty much finished and driving now.
Popped in the injectors and loaded in a tune friday and went out for
its first lil cruise. Im pretty impressed how it pulls. Shifting down is not an option without some good *** rubber because it just melts em now.
No bracket as of yet... Its only been driven once. I believe it is pretty sturdy by deisgn but i always planned on making a mount. just haven't sat and looked at it to figure one out yet. Its about winter =/
#93
I really dont care about the HP... with the torque arm, SFC's, LCA remounts,th400 with stall, and tires i want to run a good time.
The DA at the track here is often in the 8000+ so im not sure what a reasonable goal for a stock LT1 with a turbo on it... Should run out good though. Sure feels like it does.
#96
looks awesome. I would love to see some track times, or dyno numbers from this setup, just how it is... you have a lot of time in your setup, and should prove to be rather efficient as well. you've definately opened my eyes towards self-fab'ing a turbo setup like this for my car.
good luck with everything, and lets see some numbers ASAP! lol
#100
Im REALLY thinking about putting a kit toghter. The headers are fairly cheap as well as a bunch of piping. The fabbing part isnt that bad on my end, only expensive part is finding a turbo thats not a million dollars. I think your set-up is by far the best iv seen!! I like the fact that you used reg. style headers instead of a log type. Seems like it flows real good and it looks real smooth. What size piping did you use to and from the turbo? I mat start pieceing one toghter now...
