LT1 Plugs & Wires
If you use 8mm wires, you can. 8.5 are a PITA to get in the factory loom. Taylors, maybe. Some folks have trouble with them. MSD makes good wires, but you do have to put the Opti ends on yourself, as with the Taylors. Over the valve cover is definitely the way to go with LTs, and Thunder sells a set that includes the wires, ends, and centerbolt valve cover wire looms.
