PACE SETTER HEADERS EGR or NO EGR
Old Nov 24, 2006 | 01:04 PM
94lt1m6's Avatar
Default PACE SETTER HEADERS EGR or NO EGR
IM BUYING HEADERS for a 94 lt1 m6 egr or no egr?
Old Nov 24, 2006 | 01:36 PM
Razor_Blade's Avatar
A lot of people will say to do away with the EGR, but I am keeping it. It won't hurt performance and causes minimal clutter.
I believe that having the egr operational leads to cooler combustion chamber temps, which could help you stay away from detonation and knock retard. I have no evidence to support that, but I was told by someone much more knowledable than myself.
I do know that the last time I disabled an EGR, ther was a very noticeable decrease in fuel milaege.
Old Nov 24, 2006 | 02:46 PM
94lt1m6's Avatar
So it wont hurt performance to keep the egr? Will all the emmsions stuff...just hook right up were it supposed to? O2 sensors?
Old Nov 24, 2006 | 03:45 PM
The Air and EGR should hook right up. I bought the Pacesetter's with the emisions hook ups, but I will be plugging the AIR connections and deleting it. I am only going to use the EGR. If I ever get into a situation where I have to pass an emissions test I will have all of the connections to put the AIR back on.
If you go with long tubes the O2 sensors won't reach the new location. You will have to use the kit included with the headers to extend the O2's, or you can buy plug in O2 extensions.
Old Nov 24, 2006 | 05:31 PM
Armyman2445's Avatar
When I installed mine they were EGR but it made me mad try to put them in. So i cut off the EGR and welded them up smooth then they went in literally 2 secs.
Old Nov 24, 2006 | 09:25 PM
the_merv's Avatar
I took off my EGR, but I have a Cam. We had a discussion about this a while back, if you are stock, keep the EGR. When you get a Cam, then you can delete it and you will be good. The LT4's didn't have EGR from the factory cause of the Cam profile.
Your preference.
Old Nov 24, 2006 | 09:34 PM
camar0corey's Avatar
What about a car that has almost every bolt on out there? I really want to clean up my engine bay when I get my longtubes, will it hurt to delete the egr??
Old Nov 24, 2006 | 10:28 PM
94lt1m6's Avatar
So is it agreed I will buy the pacesetter long tube headers, with the egr and they will bolt right on to factory emmisions without hurting perf?
And then when I get around to a cam I will just plug it up?
Old Nov 24, 2006 | 10:54 PM
Rowdy94's Avatar
that'll work just fine. or just get the pacesetters without egr now...i dont see why not
Old Nov 24, 2006 | 11:55 PM
94lt1m6's Avatar
The only reason i have to just buy it with the egr now is that i am a dumbass when it comes to cars and i will probly not plug all the emmsions up right, and my car will run like ****.
Old Nov 24, 2006 | 11:56 PM
94lt1m6's Avatar
Nice car rowdy 94...looks just like mine...is it a 6 spd or 4
Old Nov 25, 2006 | 12:31 AM
00TAProject's Avatar
Just go with out the EGR and get some o2 extension when you order your headers.
They werent that hard to put in, I had a lil help but we did it in about 6 hours. But htat was with breaks and beer and food and distraction(girls)....Have fun!!
Old Nov 25, 2006 | 12:37 AM
93 blackformy's Avatar
I say go without if your gonna end up pluging it up anyways.
Old Nov 25, 2006 | 02:03 PM
DCStroker347's Avatar
when I also installed mine they were EGR but it made me mad trying to put them in. So i also cut off the EGR and welded them up smooth then they went in literally 2 secs. true very ture i did this process with mine and my freinds car
