LT1 Intake Oil-Leak
#41
Originally Posted by jst
Will a bad pcv valve cause a intake leak?Too much presseure in crank case?
It is a common fact that the LT1s have a tendency to leak on the rear due to high temperatures. One of the sites with a write-up on the job actually states how he talked to a GM Engineer and he was well aware of the leak.
In the Hayne's Manual it says you should change yours every 45,000 miles or so. A good way to check is if you pull the pcv valve out and shake it, you should hear a slight rattle.
As far as the intake manifold leak -- the writeup I used when I fixed mine was:
http://www.projecttransam.com/projects2.asp
Its very detailed and also has great pictures. I had to replace my lifters over Christmas break and the writeup was a great resource for pulling the intake manifold in general. I went ahead and put in some new Fel Pro performance intake gaskets (with spray on copper sealant) and some permatex copper rtv on the ends of the intake. I haven't had any issues with it yet.
