LS1 PCM on LT1.
The only obstacle I see is the signal from the camshaft sensor on the LS1, but this can could be had maybe through a converter from the opti sensor.
In discussions about doing the 4-7 swap on an LT1 the problem arrises that you need to leave the injector with it's proper bank and have it be out of sequence firing which would take away some of the smoothness and make those two cylinder batch fire. If you swap them then you have injectors firing on the wrong bank which will screwup O2 feedback if the afr needs any signifigant adjustment.
I would suggest you consider doing the 4-7 cam swap with this pcm if you determine you can make all the other stuff work.
Another benifit I see here is the wider/higher frequency range the LSX MAF/pcm support, the better resolution should have a positive effect on drivability. The LS6 MAF used on a LT1 pcm maxes out the LT1 pcms ability to understand frequency at 360gps, my little heads cam motor moves more than that. \
I have not wrenched on an LSx yet, the cam position sensor, is it a single point sensor or multiple?
To do the 4-7 swap on a factory PCM LT1 you just need (in addition to crossing plug wires) to swap the injector wires at the PCM to put the injectors back in sync with the cam & ignition. No 02 problems we have been able to find. The LS1 already has the 4-7 swap, in addition to swapping 2 & 3, if my memory is correct. Not sure how the LS1 box would interpret the signal from an Opti. Btw, depending on your tuning software, the LS1 box will run past 8K. The cam signal is triggered by a flat machined into the rear cam journal.
On the O2 thing my concern was should a problem develop the pcm adjusting injectors per bank and no onger understanding what bank an injector was on, I understand this would only be an issue if a mechanical problem developed.
With just a singal flat on the cam being the trigger for the cam sensor I wonder if the opti would work if you just made a new wheel with a singal slot for the lot resolution pickup.
Just thinking out loud here as I said never wrenched on an LSx.
Tunercat for OBD2 happen to work on those??? If not bet TC would be willing to work on it he is a great guy to do buisiness with.
So the 4-7 swap can be done on a regular crank? What about the cam? (sorry 'bout the hijack)
