Your plans for next season
Mine will come close to the limit of the stock bottom end and will pull like a raped ape
Full hand race ported heads with all the goodies including larger valves and intake (the guy is in head R&D for a major high profile race team), custom ground WILD WILD cam, some bottle, stalled, 4.10's, stickies, built tranny, full bolt-on's, dyno tune.....
If what I want works the way I am thinking it will it will make some straight up sick numbers and will not spin past 6,000RPM.
Its not going to hit the track much I think because after all this money I don't want to trash the 10 bolt just yet...
--Alan
Going with a Solid roller from Ligenfelter .. Victor E intake converted to lt1 with a 150 to 200 shot ontop.. plate kit NX. My oil pan setup getting changed to a Canton pan w/ new pickup. Hopfully going for bottom tens this year. Ohh and a 12 bolt + Transbrake in the th350, Hope the th350 hold that 150 shot off the line. The Best V8 Stories One Small Block at Time
Looking to get another one this year.
Old engine/trans/power adder coming out today, new one going in soon
I DID!!!!!!
My old setup was basiclly street car stuff.The new stuff is RaceCar Stuff
Still an LT1 Block thou
No one has been 7's and no one has gone 180 .This year it will
I DID!!!!!!
Are you still gonna use standard 23 degree LT1 style heads or SBC stuff?
if you run 13.3s w/ a 2.2 60ft. you dont need boltons to run 12s.... just put a set of fuggin tires on it and
