installed my pacesetters, fitting problem
Old Dec 18, 2006 | 11:41 AM
Taubr Unit's Avatar
Default installed my pacesetters, fitting problem
headers went in somewhat easy. But on my drivers side, the collector is sitting above the body crossmember so i can not slip a pipe over it. So i would eather have to notch the body frame rail or trim my trans mount to angle the motor back a tad, which in turn would lower the collector down. Anyone else have this problem. I would assum its because i got poly motor and trans mounts, making everything sit up that extra 1/2 in or so.
Old Dec 18, 2006 | 11:52 AM
slowmofo's Avatar
I had the same problem. I ended up shiming the tranny mount for more room. still hit the floor pan very hard on the gas...
Old Dec 18, 2006 | 12:02 PM
coldkillinTA's Avatar
i had the same problem and the exhaust shop that did my exhaust heated up the collector and ends of the primaries and pulled it down a tad with a pipe. you cant even tell its been modified.
Old Dec 18, 2006 | 12:27 PM
Taubr Unit's Avatar
did it screw up the coating? If i mod my tranny mount that should do it for me..... i hope!
Old Dec 18, 2006 | 01:12 PM
1SlowFormula's Avatar
Get out the BFH , or bottle jack and push up the section of the support a little,maybe about a 1/4", between doing that and poly mounts mine has no more clearance issues.
It's much easier to do this before installing the Y pipe, then after, ask me how I know...
Old Dec 18, 2006 | 01:41 PM
Armyman2445's Avatar
before you get out the BFH I would advise taking out your temp sensor. B/c I didnt and broke it. Save some hassle and take it out just to MAKE SURE YOU DONT.
Old Dec 18, 2006 | 02:28 PM
John, how the hell did you break you temp sensor by banging the support behind the collector? I guess Talent...
Old Dec 18, 2006 | 02:34 PM
UnitZ28's Avatar
I' havin the same problem!... coldkillin, were the headers on the car when they were heated up? ... I really dont want to take mine out lol
Old Dec 18, 2006 | 02:51 PM
here is my post about the same issue when I first came up with it...
Here are a few of my pics, from right after the install...
At that stage of the game I should have just beat that bi*ch up but didn't then had to go back ater and do it...
Old Dec 18, 2006 | 03:48 PM
Taubr Unit's Avatar
YES!!!!! Thats EXACTELY how mine are sitting. What did u end up doing? That link is dead.
Old Dec 18, 2006 | 04:05 PM
Fire67's Avatar
Uhh, if you guys would have bought the pacesetter y-pipe, its flattened/dimpled to clear the floor brace...
Dont hack it, get the correct stuff.
Or at least flatten the pipe, dont shim the trans down, bend the header, nothing like that... They will all cause other problems.
Except for the poly trans mount, they're about 1/8" too tall, shim the trans crossmember down 1/8" off the body to correct for it.
Old Dec 18, 2006 | 05:04 PM
I fixed the link, and I can't remeber if that thread tells what I did but essentially it was something like this...
I installed headers, looked at the clearance above and started posting just like you did..
then I tryed to put the y-pipe on and got it on and lined up and there looked like thre was good clearance...
test drove the car and the y-pipe was banging...
decided to change all my mounts to poly and when I pulled the tranny mount I let it hang down a bit (still had the dead motor mounts in) and banged on that cross member, only a little like 1/8-1/4" or so, changed all the mounts and have never had the banging since, even gettign good launches at the track...
Old Dec 18, 2006 | 05:05 PM
We all did buy the pacesetter Y pipe, read the link I put in above, and you'de see that in the pics...
Old Dec 18, 2006 | 05:58 PM
yes it is pure talent. I just had a few bolts holding them up and they come loose and broke it.
Old Dec 18, 2006 | 06:04 PM
Taubr Unit's Avatar
man that sucks. hummmmm, ill have to figure something out.
Old Dec 18, 2006 | 06:29 PM
Ru2slo_99's Avatar
I had the same problem, so I sent the pacesetters back to Summit and bought Jet Hots. I still had the same problem, but not nearly as bad. I replaced the motor mounts to fix the Jet Hot problem. I have seen people that have cut a notch out in that member then fill in the hole with sheet metal.
Good luck, I know how bad it feels to have a problem like that after that much work.
Old Dec 19, 2006 | 03:39 AM
transambandit's Avatar
Heres what i did, i grabbed a 2x4 and wedged it up between the header and car, i then lined up the y-pipe and slowly brought the header pipe down slightly until they matched up, then you stick y-pipe in far enough so the flattened area fits under that hump, it is no problem at all, took bout 5 minutes for me to figure it out.
Old Dec 19, 2006 | 11:34 AM
Fire67's Avatar
Dont see any y-pipe in the above pics, and if I missed it while reading, its because I tend to 'browse' reading key words till I find something of interest. So sorry if I missed that.
I had the thing hitting the floor with the stock mounts, did try bending it downward some by wedging a 2X4 against the floor and jacking up the trans tailshaft... Didnt really seem to move though.
I think trying to bend the header got me about a 1/8" more clearance, then shimming the trans cross-member down an 1/8" got me a total extra of 1/4"...
That made the hitting almost completely go away except for during hard clutch dumps.
Then I just switched to solid motor mounts.
Guess I went the 'easy' way around the problem by eliminating flex in the drivetrain.
Old Dec 19, 2006 | 12:27 PM
Taubr Unit's Avatar
solid mounts would do it i guess. I just bought all new poly mounts and i still want some sort of shock give. Im not gonna run a y-pipe eaither. So i guess ill try so just dent it in a bit and shim my crossmember and it should work i hope.
Old Dec 19, 2006 | 03:17 PM
I said in the link I put above, there is a layout of everything in the house before putting it on the car, but no biggy though, I just thought you were saying we all bought the wrong stuff. I know I didn't, it was just closer then it should have been and that was probably do to pacesetter trying to keep ground clearance...
