A/C removal
Old Dec 24, 2006 | 02:12 PM
xxxtreme36's Avatar
Default A/C removal
ok im trying to get this damn a/c compressor out and its kinda stuck. There are a few lines holding it in and they almost look like powersteering lines?????????? this is 94 t/a any help is appreciated
Old Dec 24, 2006 | 03:30 PM
93_z28's Avatar
i just cut the lines on mine.there is a bolt thats kinda hard to see so if its not moveing around real easy then you still have a bolt in the back of it
Old Dec 24, 2006 | 03:38 PM
the_merv's Avatar
Veteran: Air Force
Yea.. there is the 3 on the front, and one bolt in the back. Then disconnect the lines.
Old Dec 24, 2006 | 06:08 PM
Dragframe's Avatar
there is a bolt on the back of the compresser that dissconnects the lines... take it off a wiggle it out...
major PITA, but just keep with it... kinda like changing the plugs
Old Dec 25, 2006 | 02:08 AM
xxxtreme36's Avatar
hmmm it seems to wiggle real easily just is hung up on them lines, so theres a bolt thats holding them in huh????
Old Dec 25, 2006 | 03:32 AM
95FbFormula's Avatar
there is a bolt under it. It is used to hold a clamp that holds the tranny cooler lines and such just unbolt that and everything should come out if all other are out. I think its only like 10mm
Old Dec 25, 2006 | 07:03 AM
the_merv's Avatar
Veteran: Air Force
Yea, there is a little bracket, and a bolt under it. If you are used to working on this car, it's not really a pain..
I got my plug changes down to 30 min..
Old Dec 25, 2006 | 11:27 AM
xxxtreme36's Avatar
dang, 30 mins is pretty good. Ya i think i know the bracket you guys are talking about. Just seems like the lines that are caught are running behind the compressor and are getting trapped by the u-shaped looking a/c tube on the back. Ill try getting it today
Old Dec 25, 2006 | 11:50 AM
Taubr Unit's Avatar
be carfull there. i was pulling real hard to get mine out and it was hung on my plug wires. Pull your wires off and get them out of the way so you dont rip them apart.
Old Dec 25, 2006 | 01:19 PM
Dragframe's Avatar
I haven't changed mine.. lol... i bought the car.. drove it... tore it apart for a turbo, and put the plugs in before there was anything in the way =D
Old Dec 25, 2006 | 04:25 PM
the_merv's Avatar
Veteran: Air Force
I put a new Engine in mine, put it on the K-member and lowered the car on it. Got Plugs and LT's on that in about 10 min..
The easiest way I found to do the plugs is the Plug Socket, and a 3/4" wrench.
The way I did the AC Removal was to pretty much disconnect what I could, and cut the lines in some places to get them out easier. They are aluminum, and they bend real easy. That's up to you, depends of you want to sell some of the parts afterwards. Removing the AIR crossover tube was a pain in the a$$, it is stainless, and doesn't bend at all.
Old Dec 25, 2006 | 09:04 PM
xxxtreme36's Avatar
i got it out after taking out that rear bracket bolt, thanks so much you guys. Im leaving that crap off thats for sure.
and yes, them plug wires were in the way but i seen that before i started yanking on the compressor
