Ewp Heating Problems
Old Dec 28, 2006 | 02:42 PM
MUSTANGBRKR02's Avatar
Default Ewp Heating Problems
well first off let me thank evryone for awnsering all of my q's.
But i have the 383 in and running dyno numbers the third of January. But now i have no heat??? Car runs great around 175-180 constent but no heat just cold air! this sucks it is cold here!
Thanks
Old Dec 28, 2006 | 06:30 PM
Old Dec 28, 2006 | 06:41 PM
z28hustle's Avatar
what in the hell does that have to do with an electric water pump?!
Old Dec 28, 2006 | 06:44 PM
i dont know but it isn't working now since i installed it
Old Dec 28, 2006 | 06:46 PM
z28hustle's Avatar
are you sure everything is connected properly?
Old Dec 28, 2006 | 08:55 PM
Gun5's Avatar
my friend put a cheap thermo in his dodge its a 180 and it never heats up.. i think its stuck.. its a 5.2 dakota runs 13's
Old Dec 28, 2006 | 09:32 PM
beast69camaro's Avatar
kinked heater hose? clogged/failed heater core? heater hoses hooked up incorrectly/not hooked up at all? Not to insult your engine install skills, but I know its always simple stuff like that with me. I dunno (maybe my skills suck, lol), but those are the first things that come to mind and that I would check out first.
You are letting it reach operating temperature before you turn on the heater right? W/ a 180 deg. 'stat in mine, it takes a good 20 min to warm up enough to have a working heater.
Old Dec 29, 2006 | 06:56 AM
everything is there and connected and there is coolant running to it and the floor is not wet in the passenger floor.
i have tried it after it is running awhile 30-40 minutes or so .....
Old Dec 29, 2006 | 09:02 AM
BlackScreaminMachine's Avatar
Internet Mechanic
if you have 175-180 degree, prob more if you scan it, it has to be your heater core. If you were not even moving the temp guage I would then question sensors or possibly the thermo or the waterpump
